My Flexi FRP will save u money more than CF lips guys... u can basically twist them 180' and it will not fracture. unlike cf lips that is very stiff and britle in alot of way.
the aim for this newly designed lips is to safe your car under race environment, since gtrs are known of their brake failure, this lip will feature brake flow air_dam. and looks angry... wery very angry indeed...
will be completed in 2 weeks time.
Kelly, we'll resume the r33 project soon bro, just gathering more interest now.
https://www.sau.com.au/forums/topic/98013-front-lip/#findComment-1794421
Hey Freddy, u got some under diffusers for r33? also looking at those cannards u got to fit series 2 r33 front bar. will be used on the track so i need some downforce :D
if ur able to come up with a nice looking front bar that is suited to trackwork that would b handy also :) dont need any indicators on it, just open sections, style and downforce :)
https://www.sau.com.au/forums/topic/98013-front-lip/#findComment-1800869
Guys, i can be contacted on 0401216460
i am now doing front lip siuted to topsecret bar for r34.
Ronin 09 if u have a stock lip, yes i can do one. but i won't copy other brand.
allblitz hus, call me bro, i can always repair them.
KamikazeR33 i will soon do S2 r33 front lip for TRACK work bro....as u guys know my lips are designed to perform....and look tough...
i will post up notice on to let u guys now.
Adzmax, hey bro, if u have stock bar, i have a sick design for front lips. call me on 0401216460 we'll talk...
Mecha R32 frotn lips cut oits are for brake ducts, it will be ready in 2 weeks time bro.
https://www.sau.com.au/forums/topic/98013-front-lip/#findComment-1827071
Looks like u are doing some great work Top Stage. keep it up. I will be contacting u soon to do some custom work for my GTR.
I am wanting a carbon fibre bonnet for my R32 GTR with Vents that look similar to The R34 GTR NIsmo... eg backward facing for engine heat extraction.
Also wanting a carbon fibre front bar.. original style... with the flexible bottom lip that u are working on. Even maybe a bonnet spliiter that came as option for Nismo and N1 r32 GTRs
https://www.sau.com.au/forums/topic/98013-front-lip/#findComment-1851028
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
