Just installed my "C's short shifter", ordered from japan through Unique Auto Sports.
And what a bloody differance.:P
It has turned the feel of my R33 from a luxury sports car to a true sports car. The throw, of the shift, is just perfect and the box actually feels alot tighter. Took my car around Calder Park (Melb.) on the weekend and the speed of my shifts dramatically improved, even my mates watching from the side line heard the difference.
I would recommend this upgrade to anyone.
Note: Your synchro's must apparently be in good condition
Forget about the NISMO short shifter it is only 10% shorter and barely noticable.
And yes it is a bit pricey but i have absolutely no regretes and no problems recommending it.:jump:
https://www.sau.com.au/forums/topic/9805-must-get-one-of-these/
Shameless plug:
I'm bought a couple of C's Short Shifters whilst I was in Japan, and selling them for $450 each plus shipping...
http://www.skylinesaustralia.com/forums/sh...=&threadid=9532
Originally posted by JiMiH
Even if your synchros are in good condition .... I heard that the short shifters help to adjust that :(
Well i will keep you posted if and exessive wear is noted. Till then just send a post of how my car looks from it's ass end!:lol:
Originally posted by Merli
Shameless plug:
Damn!!!
I wish i found this site earlier:mad:
Yeh great your a genius you know what double clutching is. Thay wasnt my question. Perhaps i should clarify.
But what is over selection, putting too much stress on selection forks??? or is it going to 5th when wanting third, 2nd when wanting 4th. I havent heard this term before.
I have the C's short shifter too and when my car is cold 2nd really crunches - even at low revs.
My car came with this from Japan so I can't compare to the original shifter but I can say it does feel good shifting with it (when it's warm). Very tight feeling and quick to shift.
overselection is putting pressure on the shift fork past the gear engagement point. Resting your hand on the gear stick when driving does this as well. The overselection may will wear the weakest part, some gearboxes this is the shift fork others the gear/syncros.
i just installed one in my car on thursday night, and i must admit it was one of the best $500 i have spent (so merli's ones would be a bargain!)
Feels really nice now, nice and direct... i was a bit worried about installing it, but when i was doing it it wasn't so bad at all (hardest bit was removing two c clips!)..
I took pictures while i was doing it, but my cable modem is dead, and i am not sitting on dial up to upload them :P i will try on monday though..
so if anyone is thinking of doing it! as nike says, JUST DO IT!
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
