oh and manages13 my block and head machining has taken over 23 weeks alone (NO assembly at all) thanks to those involved
shit brad the company i have been using will offen do the same day drop off and pickup if i prebook a week or so out B)
DUDE that is one nice list i only cringe at what it must of cost to put together as i know how much it cost for me to get my build together. Can i ask who you are using for the build and tune? and when you might have it on the road?
pete
  • Replies 315
Thats definitely a dream setup.
Very nice pics.
With regards to the rb30det thing.. I think the biggest concern is the height. One big advantage of the 2.7 kits from japland.
But revability... Its got everything to do with gearing and how well the hotside flows. The VL's run a 3.45:1, run that in your Stagea and it too will feel like a big diesel. :(
Edited by Cubes
pete
tuning will be at Racetorque im 99% sure on. they mainly do race cars, and keep quiet in the performance scene in perth. been highly reccomended by another gtr owner with autronics and over 550rwhp.
the build is all done at home, machining hassles where through a few well respected perth shops but failed to show reliability and the shops told me 3 weeks for the block MAX and 2 weeks for head MAX. well im still waiting on the head which has been 12 weeks and the block was 11 weeks :angry:
PM me if u want the name of the shops i used for machining, as i dont want to upset the moderators :)
cost, hmm well im not gonna announce that here, bit over original budget though :lol:
should be in the car by xmas and run-in/tuned by end of january pretty definately. depending on the tuner :)
cheers
Brad
Is anyone else touching themselves looking at those pics?
Adrian
Yes i did...
Wow whats a setup i am jealous...
I think you have done the right thing with the 2.7 kit...
3 litre kits belong in R31's......
Hands down to you Brad, very nice job on your build - all top quality parts there. I'm sure you'll get power with reliability with all that gear.
Good luck with the build and keep us dated on the progress.
thanx guys, well im picking the head up tommorow finally, BUT it isnt assembled as i need shims for the valve springs, cause apparantly the JUN cams are regrind and have a smaller base circle.
so they aint even billet like HKS ones and are regrind from GTR cams. (thats the words of the shop doin the work).
so ive decided we will assemble the head as well, with the help of my uncle who usually does drag engines. shims will be arriving monday next week supposedly.
pretty pissed about the cams but, thought JUN was better than that? B)
does smaller base circle mean they are not as good in making power as a set of hks normal base circle size ones with same degrees and lift?
cheers
Brad
They weren't able to machine up shims?!?!?
The reason for the smaller base circle is to allow for a higher lift without or with very little head modification.
Tomei also uses this method to squeeze out a little more lift.
Edited by Cubes
no they said the largest shims they had were not big enough and they needed "special" ones made or some shit. sounds like an excuse to charge a shit load of $$$ for f**k all :) gotta be custom made and specially heat treated or something they said.
i took the head off the shop cause they have had it 13-14 weeks to do porting and reassemble, so they ported it and wait till now to check the cams and whether shims r needed and now they delay it another week, plus assembly time. so i told em to not bother and i will do it.
Dont mean to burst your bubble but make sure you get it tuned by a reputable tuner. We tuned a 500hp built 930 Porche TT over here on the Gold Coast. It had been tuned by some guru in Perth that used all of about 5 of 200 available features of an autronic. The car was that rich that it had washed the bores!!!!
I was going to say give Greg at proengines a call about shims, he reshimmed my head and it was a pain in the ass but he got it spot on, with no bullshit. He has posted above me though, so thats obviously where he got the shims from ;)
cheers
Brad
Hi Brad, all of the Jun cams I have seen are billets. They have to use a smaller base circle to get the lift, RB cylinder heads don't have enough room. The Jun instructions and web site both quote the following for all lifts over 10.5 mm;
Clearance of head for cam lobe rotation required.
Special valve spring required.
Special valve retainer required.
The "Special valve retainer required" means the cam has a different (ie; smaller) base circle to standard.
:) cheers :D
There seems to be a few people that are having trouble with machine work being done on their engines, either they are very slow or not done correctly.
Greg at Proengines posts here on the SAU and the work he has done for me has been nothing but exceptional and in a timely fashion. Won't go anywhere else now.
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
