  • Replies 315
Good work Brad, things are looking good!!
I deal with workshops that are actually going to do the job, only way of quality control.
I know I may of mentioned this before but Greg from Proengines (username: proengines) does some excellent work. He has always been honest, reliable and he even does the followup after the job is done!!
Anyway shims are not too bad to sort out, even when you think you ordered the right sizes they do at times need adjusting, just time consuming stuff but easy.
Merry christmas to all!!
Adam
PS. I know your running the Autronic SMC with Autronics CDI, what coils are you running?
Just finished my CDI install - Autronics SMC , now with Autronics CDI & running 6 x Mercury Outboard Coils.
Adam
msd coil packs im using
and the shims are easy to sort out but the fact they are wrong and i pay a shop to sort it and i get the wrong gear supplied, just frustrating after the 6 month wait for machining and i thought i could finish the whole engine this weekend, or this next week and now i gotta source more shims between boxing day and new years which i doubt will be enough time.
i just want it running dammit :)
proengines (greg) has been very helpful online with my queries, and if i did it all again i'd use him for the machining and stuff rather than these local "gurus"
Brad, if you run into any problems with the CDI unit, I set mine up all myself. I had to even solder a chip into the SMC ECU but you won't have to do this as I had dwell chips to control ignition before. The Ign output are incorrect on the installation instructions - cost me 4 days of pulling my hair out to sort it out.
Can't wait for you to get this all together and started!!
Adam
nice. did you polish the plenum yourself? it looks very nice :starwars:
yep polished it at home on the buffer (my old mans the polishing guru), its a pain in the arse and a messy job but looks sooo much better than tacky painted stuff everywhere.
ive polished the plenum, throttle bodies, alternator, intercooler piping, rocker covers, centre coil covers, timing cover, CAS, catch can, and a few other bits and pieces.
if i had to do it myself i dont think i'd have the patience, but when its free and done by someone else its well worth it :lol:
all the bits where polished 3 years ago now when i first had the rb26 in the VL calais. so they stay pretty clean, except they need an occasional buff over it all to get greasy fingerprints off, and show the mirror finish again.
Brad
Just looking over everything - would it not be a good idea to ceramic coat the exhast manifold and perhaps the exhaust housing of the turbo while everything was out and easy to get to?
Dan
hey guys, finally got the engine in today and 99% of the stuff is hooked up so not long to go :(
just got i/c piping mods and exhuast to be done to the cat. couple of other bits and pieces, but mostly ready to go
heres a pic i took earlier today, not long now :)
we had to spin the comp cover to face the passenger side gaurd to get the 3" cooler piping to fit, as we initially had it pointing down towards the chassis rail.
i havent crawled and fiddled under a car and in the engine bay for over 6-7 months now and god damn its a pain in the arse, as everything is soo hard to get too compared to sitting on an engine stand :)
few weeks and she will be ready for the run in tune and then after the run in is done, some power figures on the dyno :) i've told my tuner i want 500-550rwhp max at the moment as i gotta save the gtr gearbox from breaking for as long as possible (till i get some more cash for upgrade), and tuner said i'll need around 17-18psi for 500rwhp which is pretty low boost and then when i get that nice gearbox ill wind it right up and hoping for as close to 700rwhp as i can get (and push the t04z to its limit).
only time will tell, and im bound to have a few hiccups along the way as usual B)
cheers
Brad
Edited by CruiseLiner
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
