Hi all...
Just in the process of rebuilding my motor.
2 questions...
1..... Should I use 'running in' oil for the first 1000kms or so?
2..... What is a good grade of oil to use for the RB25DET motor?
Please don't give me a response if your just guessing.. I need a solid reply from someone who really knows the best oil for this motor.
Thanks...
you wont get guesses, you're going to get opinions. a shit load of different 1's. everyone has their preference.
if you want a solid answer, use the oil nissan specify. i think it might 7.5W/30
http://www.skylinesaustralia.com/forums/in...showtopic=22458
Thanks..
ok.. point taken.. let me refrase my question... I'm after an answer from someone who has used and oil for this motor and has been happy with it.
My main concern is whether or not to bother using a running in oil or just go straight to the oil that I will use for every day use once it's run in??
Everyone has a difference in opinion so if anyone has been there and done that, let me know..
Thanks
I use running in oil, drop it out after about 100 km and change the oil filter . I refill with the same stuff for another 400-500 km then drop it out and change the filter again and use mineral oil for the next 2 oil changes about 6 k k's then use synthetic oil on the next change .
5w40 or 10w50 , but it will depend on what you use your car for .
I have used the same basic running in process for lots of years and on many engines;
Castrol GTX (the basic no frills mineral oil) with new filter.
Run engine for about 1/2 hr or until well warm.
Change oil filter. Engines can have particles in them that acccumulate during the build/maching proces and they need to be removed from the engine ASAP, these are caught in the oil filter. If you leave them in, the oil filter can get blocked and so it will be bypassed ie; no filtering.
Check the basic tune on the dyno or on the road with portable lambda sensor.
Drive to Bathurst and back, around 500k's, lots of varying conditions, up and down hills, freeway, long climbs etc. Don't rev the beegeesus out of it, gentle but firm, change throttle openings often, no slogging it in high gears with lots of throttle and load it up with partial throttle openings going up hills.
Drain the GTX and remove the oil filter.
Refill with Castrol Formula R Synthetic 10W60 and fit a new oil filter.
Do leak down test, if OK then final tune on the dyno.
Go racing
:D Cheers :(
Edited by Sydneykid
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
