standard is a low mount, but you can go high mount with the whole external wastgate thing but low is good looks kinda more stock if you change turbos they still stay in the same location, as for the ebay high and low manifolds they sean to be pretty crappy quality and dont line up real well with motor and turbo ,a few guys here have used a hish mount and lots of modfications were needed to make it fit, and the stock one presuming you staying with a low mount turbo setup is good for power over 300kw maybe more , i one did see som usa made ones one there and looked of good quaility very similer to the trust one.
moral of the story ,stickwit what ya got :)
https://www.sau.com.au/forums/topic/98121-turbo-manifolds/#findComment-1781579
I got a xs power lowmount manifold and it was a fairly straight forward to fit.
It changed the note of the engine a little (little smoother) but I dint really notice any power increase to be hournest.
I recon stick with your stock one and if you rewqire more flow get the stock one flowed etc.
https://www.sau.com.au/forums/topic/98121-turbo-manifolds/#findComment-1781710
But the stock one looks ugly
so?
and I do believe that there is a potential power difference between hight-mount and low-mount turbos.
hight mount can make more power.
because the speed of the exhaust flow is porportional to the temperature, and there is less time for exhaust heat to bleed out of the manifold on a top mount.
Thats the theory. Though I dont think it makes a difference on any sane (or even semi-sane) budget.
I also THINK that a high mount turbo gives better airflow? or is easier to keep cool or something...
https://www.sau.com.au/forums/topic/98121-turbo-manifolds/#findComment-1786010
Because the turbo is so far away from the head it does give the engine a lower running temp which will allow you to run more advance timing which means extra power yes
So a high mount would allow for a more agressive tune... Thats what I was told =)
so?
https://www.sau.com.au/forums/topic/98121-turbo-manifolds/#findComment-1786227
more or less yes!
i have an xs power one and its ss..its gusseted with webs and supports from all runners and the exhaust flange is also the same..pretty bloudy good for a cheap manifold..only prob was the holes didnt line up..i had to die grind the bitches out to suit.
They reckon manifolds made from steam pipe are better...which is true..cause ss does get brittle after it is exposed to too much heat. where a high tensile pipe like chromemoly would never crack or break. but usually costs an arm and a leg.
https://www.sau.com.au/forums/topic/98121-turbo-manifolds/#findComment-1787314
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
