(Use this as a guide for new threads. Delete and/or copy the fields as needed - dont forget to add your location in the description field above. Delete this message)
Item:r32 gear&handbreak boot leather
Item Condition:new
Reason for Selling:extra
Price and Payment Conditions:$70 free postage
Extra Info:brand new, blace leather, with metal wires,
Contact Details:0402736958,ben
https://www.sau.com.au/forums/topic/98154-r32-gearhandbreak-boot-leather/
