Anyone recommend window tinters NOR?
May need a quick removal of tint on my V35 rear windows before licensing next week.
Only seen the car in pics and it looks very dark.
I heard there is a new tint available that is dark but legal...Is that true?
https://www.sau.com.au/forums/topic/98166-window-tinting/
TKO - did my BMW earlier this year - i am not happy with the result. Front two windows have bubbles and ripples. I have been meaning to ring him but have been way to busy.
Current TRendz did my old skyline and HSV and was a fantastic job.
TKO brother (Nathan I think his name was) - did my astra and also did a great job.
So my personal opinion on the 4 cars ive had done:
1. Current Trendz
2. Nathan
3. TKO
My opinion only.
Daniel
Edited by IMACUL8
https://www.sau.com.au/forums/topic/98166-window-tinting/#findComment-1783367
Check the whitepages (not online) for Peter Gardner or Gardener tinting ... was in Malaga or thereabouts.
I've had 2 cars done through him and know of at least 4 other people who have had multiple cars done through him.
Great guy, great service.
https://www.sau.com.au/forums/topic/98166-window-tinting/#findComment-1783632
Peter is my uncle
he's in morley nowadays (right across the road from the ford dealership)
he does it from home and only uses qaulity material
no such thing as a dark legal, its just the colour of the film and glass that gives the effect
his contact number is 0439 877 978
let him know Adam sent you :)
https://www.sau.com.au/forums/topic/98166-window-tinting/#findComment-1784959
Thanks Guys
I will also need the tinter to fit the Tailight Overlays I got from the US
http://photobucket.com/albums/y42/BlueBatm...epics0013-1.jpg
They look tidy Chris, who did you get them off in the USA and what are they worth to buy.
To be honest I just use Solar Tint in Vic Park and I havent had a problem yet.
https://www.sau.com.au/forums/topic/98166-window-tinting/#findComment-1784992
Thanks Nigel, They cost $42USD plus shipping.
Here is his website
http://photobucket.com/albums/y42/BlueBatmobile2005/
I'll have a look for his email address
Cheers
https://www.sau.com.au/forums/topic/98166-window-tinting/#findComment-1785246
Everytime I look at the G35 it gets hotter and hotter, I mean look at this one
http://photobucket.com/albums/y42/BlueBatm...current=dg1.jpg
no offence R34, I like black better :P
BOT: With this tinting business what was the darkest you can go? is it 35%?
I will look at getting mine done in January I think, can't stand how bright the inside of my car is during the day now that its summer...I might try your uncle Pete if thats alright Adam
https://www.sau.com.au/forums/topic/98166-window-tinting/#findComment-1785679
no offence R34, I like black better :)
None taken mate
I've had black and they look so good until you spot the dust accumalating while you're still using the chamois after washing.
But yeah nothing better than a black well polished car
This is my favourite pic.
http://photobucket.com/albums/y42/BlueBatm...current=dg2.jpg
Love that Kenstyle bumper
https://www.sau.com.au/forums/topic/98166-window-tinting/#findComment-1786195
topaz fine by me :(
35 is the legal maximum but dont get caught out and think that by applying a 35 grade film to your windows that the total grade will be 35.
the glass will reduce it to 30 or so (depends on a few diferent things such as colour of the glass)
mine has 15 on the sides and 35 on the back just incase if i get a yellow sticker ( the rear window is the hardest to apply the film to )
and F**K YEA the g35 is sex! cant wait to see one in the flesh
https://www.sau.com.au/forums/topic/98166-window-tinting/#findComment-1787252
If you have only seen the glass in pics then it might not be tint at all.
my r34 has darkened glass which is like really dark tint like but is not tint.
It is 100% legal and you can pass the pits with it..
You're correct.
I found out it is factory "privacy" glass.
Where did you get your R34 licensed?
Would prefer somewhere they have had this issue before so I don't get hassles .
Will need to get the fronts tinted to match while staying legal
https://www.sau.com.au/forums/topic/98166-window-tinting/#findComment-1788188
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
