It should run (relatively) fine on the base map.
Your problem happened to me also. Because the loom is connected to the ECU by one bolt in the middle, the edges can lift up slightly causing the problems you describe.
I put a long cable tie around the edges of the power FC to ensure a secure connection.
https://www.sau.com.au/forums/topic/98168-power-fc-install/#findComment-1788069
