Top up the brake fluid in the master cylinder.
Don't ask why it only does it on right-handers - just that experience says the first place to look when the warning light comes on is the brake fluid level.
Pull your centre console out, and check the handbrake warning light wire is connected properly, and has no parts that are earthing onto the chassis anywhere. It may have wiggled loose, or may have some stripped insulation somewhere and swings somewhere it can earth only when you swing it right....Hard to say man, but definately worth a look :(
Steve
