well i was going to post something with a bit of a introduction since its been barely a month since I finally got my R32 GTS-T but unfortunately my post is going to be a bit of a sad one.
Was driving home tonight at 80km/h (the legal limit i might add) and heard a loud bang. Back of the car lurched and the car spun and the back right hand side hits a huge dip on the other side of the road backwards. (this whole incident happens in the blink of an eye)
Anyway getting out of the car its obvious that I had had a blow out. Unfortunately hitting the huge dip on the other side of the road has caused some damage and the wheel is bent at a pretty big angle now ;)
Hopefully nothing else like the HICAS is damaged
Great just got a new clutch put in and this has to happen....
Funny part of the story is that the car following me didn't even stop and help :P
bad luck deo :P...i guess you can be thankfull it wasnt any worse and you came out ok.
i'm guessing a rear wheel blew out? man i'm always paranoid of blowouts, for some reason i'm always driving with 1 hand and thats a big no no if something blows.
damn.
a blowout would be when your tyre bursts/pops, hippy.
I'm kinda scared of this happening to me atm, considering the state my tyres are in :P I need new ones badly ...
welcome deorbit
sorry it wasn't a more happy introduction ;)
Yup, I've had the same happen in my first car. Obviously a nail embedded in the tyre just decided it wanted to go at that moment. Not much you can do. I was lucky that there weren't too many cars on the road and a wide shoulder. At 70km/hr though its definitely scary when you just don't know what the fug has happened just that you can't steer anymore.
I ended up sliding off and knocking over a small tree. The damage wasn't too bad and i didn't really give a rats about the car too much, but I was pretty lucky. Could have been much worse if there was a big sized tree or I was in the right lane or something with other cars.
btw: You're looking at maybe a thousand or so to get what is damaged repaired (depending of course how bad it is), but at least it wasn't worse and you're on here to tell the story. HICAS isn't that important, if its damaged you can rig it up to do without.
Happened to me at 105km/h in the middle lane on the western ring road once... Rear tyre - not pleasant at all. Didn't loose control or anything, managed pulled over as soon as I could merge to the emergency stoppign lane - no damage to mechanicals, just the rear mudguard panel of the car damaged where a 36-inch long piece of tyre had delaminated, bent the panel then torn off and was left on the road.
Wouldn't want it to happen in again! :P
Haven't had a blowout for more than 25 years. Had two about 10 minutes apart whilst doing well over 90 miles an hour in a Triumph 2000 MD PI. No panic....no drama.. just a loud bang followed by a strong but easily controllable pull to the left. Only problem was by the time I had stopped from that speed the inertubes were totally destroyed just a collection of little rubber balls and shreds inside the tyre...........So much for modern suspensions!!!.... maybe it's the HICAS which causes problems
Round about that time my family and friends were in a Falcon station waggon that blew a front tyre at around 100kph.......it did 3 complete rolls ending up on it's roof....they were very lucky to survive. One reason I've always driven imports and never owned a Ford or Holden
Back to Skyline.... it drives and handles so well I just can't believe it turns into an uncontrollable heap of junk if a tyre goes flat.
or ....is the average Skyline driver incompetent???
come on guys......how about some informed comment
I am into triumphs and owned a PI which I rebuilt and warmed up. Which Triumph was it a 2500PI or did you put the fuel injection on a 2000?
Mick.
The origional PI was the Mk1 body with 2.5l lucas mechanical fuel injection.
Mine actually my first of 3 or 4 was a Triumph 2000 MD an Aussie Special Edition I believe. It had chromed wire spoke wheels and an MD badge :( I swapped in the 2500cc PI motor and Injection. Used to piss off a lot of hotty Holdens and Falcons and blew off my mates GTS Monaro (go the V8 power!!)
The Triumph 2000 and 2500 were and still are a very underated car
Yeh i was thinkin the same thing last time i blew a tyre it was pretty dam subtle and i took my time to pull over (eb falcon) the tyre was shredded, back left tyre, but i didnt do any of this crazy swerving stuff u guys are talking about. I think they design em so that its not suposed to happen cause tyres do blow quite often.
Were u yankin at the steering wheel like a cheerleaders bra or sumfin? was it wet? looks like uve been driving a few years so i wouldnt have expected u to pull a boxhead. Scary stuff if blowouts do that. U mess with ure camber/castor settings at all?
Wasn't doing anything too fancy. I had just finished going up a hill and was a bit of a turn up ahead. The car ended up pointing towards the other lane after the blowout which is where it all went bad.
Hey either keep the car straight and go into on coming traffic or try and correct before I end up becoming chop suey.
Only reason why I'm alive now is because the Skyline does handle so well!
btw The rear right lower control arm is bent. Apparently around $180 to get another one. Doesn't seem to bad. Hopefully nothing else is stuffed :D
I guess the experience varies... Mine was very uncontrollable and wasn't much i can do. The totally handling of the car instantly changed and it was difficult to control. It was hard to tell in mine whether it was the actual wheel blowing first, and when it went up the curb it bent the control arm, or in fact he control arm separated, which in turn caused everything to go pear shaped. All I remember afterwards was all these people seeing whether i was ok, and this huge hissing sound as the air was pissing out.
Was quite a few years ago now, but i still remember it quite well.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
