Originally posted by predator666
All I remember afterwards was all these people seeing whether i was ok, and this huge hissing sound as the air was pissing out.
Was quite a few years ago now, but i still remember it quite well.
bro ... i remember that too :)
ok got the replacement control arm, finally got the mobile mechanic to take take the old one off and we find that the replacement one doesn't fit! arrrgh!
now I'll have to wait for the wreckers to open up on Monday to replace it!
deorbit Sorry to here about your car!
If you people are so worried about geting a blowout/flat buy the biggest rim dia. and the lowest profile tyre as this will reduce the affect of a blowout at high speed!, or you could buy some of the "run flat tyres" that are available on the market at the moment, with these tyres you can do 60kph for hundreds of kilometers with out any air in the tyre at all! (Just because its designed this way doesn't mean you have to run it flat either!It's just a precaution)
But as with all new things on the market time will only tell how good they are or how good they get!
They are designed with a ring that sits in between the rim and tyre aswell as having a stiffer sidewall construction! These tyres are also less prone to delaminating as the ring helps hold the rubber to the rim!
Good news for all the ladies who don't want to have to stop by the side of the road to fix it (we all know how dangerous this gets) and bad news for all the hubbys that have to change the tyre when the lady gets home. :P
Also there is lots of no-standing anytime zones (yellowish lines painted by the side of the road) so that it might not be possible to pull over and change the tyre straight away!
MEGA
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
