hey everyone.
in the near future im looking at heading to regency for my roadworthy compliance for my 32gtst...
ive got all the instructions and stuff and im gonna need a few bits to get it thru.
when i got the car it came with a pod filter, fmic and body kit.
naturally the front intrusion bar has been eaten by an angle grinder to make airflow for the fmic, and this obviously isnt going to pass so ill need one of them,
as well as the front bar itself,
airbox,
stock intercooler and some piping,
steering wheel,
can anyone recommend good places to source these bits?? id like to borrow what i can if i can coz this will obviously save me alot of money... any suggestions would be great, even if u reckon i could get away with the fmic or pod would be great news!
thanks.
https://www.sau.com.au/forums/topic/98186-regency-for-compliance-soon/
yeah i already spoke to some guy there and he said it was ok..
EXCEPT - (this is where the fun begins)
ive got a bit of paper here, which was sent to me from RTA talking about it all
GENERAL CONDITIONS:
That on post 1974 vehicles, the engine must remain standard and retain its original induction system.
That the engine MUST retain the original equipment induction system; ie, carburettor, inlet manifold, camshaft, air cleaner, ECU and fuel injection system.
That all emission control equipment and associated plumbing originally fitted must be retained and operational
The fitting of turbo timers, non OEM blow off valves and mechanisms to vary turbocharger boost pressure are not acceptable
so from what i can understand is that to comply the car - you gotta have it like this (plus other conditions that i havent listed but have here on this bit of paper) but if you get defected you can have some of the stuff as aftermarket so long as it doesnt break other rules, like you mentioned it has to be secured etc.
It depends which a$$hole you get at Regency as to whether you pass or not.
Take your dad with you when you go, and see if they go easier on you.
It is pure pot luck, and the rules change depending on whom you ask.
Good luck!
i was thinking about getting my dad to take it in for me..
surely its gotta do something to help my chances..
lets see, 19yo P plater vs 56yo gentleman... lets see what we can do for you sir..
'shes all good mate, just get *something* sorted out as soon as you can'
vs
'you have to change this, this this, this is broken, this is worn, replace this, spend money on that'
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
