  • Replies 100
Hmmm i'm more of a vl fan for sure. It was my first car. Just make sure the cooling section is clear and pressure tested, cause they have a habit of cracking heads (as mine did) apparently there's some mod that can be done to stop this happening.
Still i reckon they're better looking, but thats just personal preference. Get a calais, they're the sex
https://www.sau.com.au/forums/topic/98189-r31-or-vl/#findComment-1783474
VL, radiator has a section in the middle to direct the water through the core, it can become loose meaning the water bypasses the radiator, doh.
VL is lighter, but flexier, esp in the rear end.
There is some minor difference in the engines (i think plenums differ to clear the low VL bonnet), makes like 2kw difference or so i'm told.
VL i'm sure has a fairly extensive aftermarket, since they are a bit of a cult car, probably cost more then a R31.
Diffs are very similar borg warner units in the two and the LSDs in both are shite.
Take your pick really :).
VL is probably a nicer looking car overall.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/#findComment-1783580
vl are shit anyone hwo has driven one then a r31 and compared the chassi always walk away with a r31
people who like really shit interiours buy the vl
people who like build quality and something abit more square get the r31
i think the r31 looks alot better but hey im no drag racing vl lover who thinks rb30 were a holden engine
lol
Edited by fatz
https://www.sau.com.au/forums/topic/98189-r31-or-vl/#findComment-1783617
I currently own a NA VL Auto bout 5 years
My was and still my first car- keep me out of trouble till I got to 25+ to get a “sportier car”
Why did I go the VL
1) it’s so slow I can’t get into any trouble if I tried
2) heaps of cheep parts/servicing is cheep
3) cheep to insure compared to the VL turbo/R32GTR
4) had tasty mods/paint/rims when I got it:
Nice 17” rims
Cold air induction
3” mendal bent exhaust- 5” tip
Fairly new pain + colour coded bumpers
New interior
And I put in :
central locking
Alarm + 3 point moibliser
2.3k worth of stereo
2 small kangaroo dents (bloody roo’s)
All I can say is get a manual anything- make life interesting
You really need to give us more info:
Your age- insurance is greatly depended on age/driving history?
Is this your first car?
Intended use for the car?
Will there be future mods?
With this info we can help you more! (More relevant opinions)
I would swing towards the R31 cuz there is a lot less stigma associated with the R31’s than VL’s
The RB30 is quite hard to kill- but can easily be undone by the cracking heads “problem”
I don’t see it as a problem but more of an opportunity to put a RB25 head on and get an extra 30/40% out of the RB25/30 hybrid (NA RB30)
or just dump in a RB20/25/26
VL and the R31 are cheep, heaps of parts and can have heaps of mods before cracking open the engine for expensive internals
Me- id take the R31
Gets less attention from bogans/theiths/police- more of the sleeper
Say you wanna buy a VL?
https://www.sau.com.au/forums/topic/98189-r31-or-vl/#findComment-1783742
i had this choice years ago and i went the VL got a VL Calais it was a good car i quite enjoyed it
never owned a R31 but now own a R32 GTR
but looking back on it i think i would have enjoyed the R31 just a little more
so yeah another vote for the R31
but do you really think a skyline forum is the best place to ask? if you went to a VL forum it would be VL most voted for
RellikZephyr
https://www.sau.com.au/forums/topic/98189-r31-or-vl/#findComment-1783983
WERD. I have owned both and I can say the r31 is better in every aspect.
I heard that the rb30 cost Holden heaps to buy off nissan so they had to skimp on everything else. Having owned both I beleive it. Build quality is crap in vls.
Also an r31 handles much better than the vl. The vl often feels like you're driving on ice compared to the r31.
Some people think they don't look good. IMO they can look just as good if not better than a vl.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/#findComment-1784032
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
