  • Replies 100
R31...
They are better sorted from factory.
Lower diff ratio that accelerates the car quicker.
Better cooling system setup.
Nicer stiffer chassis.
My sister recentlyish bought a NA VL that had done a genuine 137,000km's. It was spotless.
First thing we did was throw a bran spankin new radiator in it, new genuine nissan thermostat, new clutch fan and gave the whole system a power flush.
~9months later without a warning it started to run on 4cyl's.
No overheating nothing, it sat solid on the 2nd notch. 1 nasty arsed cracked head. The cooling system was perfect, there was ZERO reason for the crack.
Now its sitting in the old mans shed next to her previous VL that also has a cracked head. :S
I prefer the exterior look of the VL, especially a nice dark coloured VL Calais.
Edited by Cubes
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/2/#findComment-1785469
When you swaped the radiator/cooling set up
did you blead air out of the system?
There is one little bolt that you losen to let air out after you have added the fluid. oppsite side of the engine to the alternator should be a little yellow sticker
How did you pick the cracked head:
Oil in cooling fluid?
Big mofo visable crack?
Running on only 4 cyclnders i.e. missing when ideling?
Compression test?
Sounds like a good time to swap heads or even engines!
Edited by NAman
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/2/#findComment-1785717
Yes Cooling system was bled.
Running on 4cyl's is zero compression in cyls 5 & 6.
There was no oil in the coolant or vice versa.
The head simply cracked, lost compression in cyls 5 & 6 and 100psi in cyl 4, it ran like a pig, sis drove for 10km's to home.
VL's can sometimes run for months with cracked heads and no tell tale signs, depending how bad its cracked.
The water in the oil usually shows up in the PVC valve before anything else all though there was none in there.
I was hoping a headgasket as it went so suddenly, no tell tale signs like usual. It simply cracked and cracked bad.
It wasn't using any water, it was running perfect and not thrashed prior to the head crack.
Ripped the head off.. she's cracked. :P
Its simply holdens lack of R&D in fitting the rb30 in to the VL + the fact the rb30 head does have a weakness. R31's crack heads too... just not if the cooling system is good unlike the VL's.
A mate of mine had the same thing happen to his VL. Perfect working order then crack.
The VL I bought when I was 18 never cracked but I did sell it within 9months to upgrade from that yucky interior.
My RB20DET was cooking and I didn't realise due to just purchasing the car, just smelt hot and spewing out coolant. It ran like that for a complete summer, replaced the temp sender realised it had been driving around on the H!!! That still ran fine for many years after and a solid 100,000km's. :D
Edited by Cubes
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/2/#findComment-1785743
If you wanted un un-biased opinion, this isn't really the place to ask.
Wow, what a surprise, everyone says "go for the Skyline"
Now go and start a duplicate of exactly the same thread on http://www.calaisturbo.com.au and see what sort of response you get.
:P
I vote you got for the VL.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/2/#findComment-1785862
My only worry is that he will just assume we are all biased because this is a Skyline forum. Its not all bias, the reality is that the Skyline is the better car. I'd be interested to hear what points someone could put forth to say the vl is better, other than they like the look of them better.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/2/#findComment-1785977
I can't say I'm a fan of the R31 looks (apart from the coupes).
None the less here's my argument against the VL.
OMG... WHAT CHASSIS RAILS!!! No wonder they have been known to pop windscreens and flex like buggery.
Which would help explain why they weigh damn close to the weight of an R32 that is a smaller car.
Edited by Cubes
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/2/#findComment-1786020
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
