  • Replies 100
I had a VL for years... never had any real problems with it except for the regular, cooling and such. Both are very reliable (hence still seeing so many of the fu*%ers on the road) and pull great cred. But I'd go for an R31, Silhouette version if possible, stonger auto and came with an LSD. Plus had electronic instrument panel in the dash for, KM's till empty, fuel usage and a few other features.
So yeah 31 dude, even if they are a little more expensive. Plus better re-sell value.
Cheers
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787194
SHHHHHHHHHH MARK!
geez.. the more people that buy 31's, the less goodies are left for us!
baahahaha
Theres not contest really. R31s have everything better, the only good thing IMO (apart from the calais frount) about the VL is the Rb30, which is rooted by the cooling. R31s rarely have cooling problems, but the factory power steering is f**king dodgy as. when it works it works well, but its hard to find one without the pump or rack leaking. Mine do..
Either way, enjoy your lifter tap.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787382
I would take a mint calais over a TI R31 anyday of the week.
The R31 does have a better chasis, build etc.
But to be honest the local model R31's have never done anything for me.
Import 2 doors are horn though.
Still wouldn't ever sell my calais for R31 though, even though i like the import R31 models.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787434
The reason they crack heads and have problems is because gm mounted the radiator to low its lower then the hose ,if you look at r31 the radiator sits higher,just mount the vls radiator up higher and it saves the head ,every vl nut knows this.
Laterz
I would go VL calais anyday they are hectick!!!
8OOSTED you forgot to add in vx clubsport leather interior and there massive brakes !!
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787832
In VIC, any VL thats cheap will be more than likely thrashed. R31s have more older owners and its easier to find a clean example. Oh and the police wont look twice.
For practicality the 31 got better gearing, air con standard, power steering standard, 4 wheel disk brakes standard, couple of KWs and boots that can double as a pond in winter lol.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787877
i worked in a cyclinder head recondition place for awhile and we got falcon heads 10 times a day and vl / commodore heads 5 times a day. but we never ever got a rb30 head off a skyline... never... and my boss said to me. they never get em. only VL's coz they fudged it up.
if you wanna fit into the bogan scene get a VL and do it up...
get the r31, do it up and it wont look so bad. look tuff etc. but prepare to be mocked by other skyline drivers that drive anything newer....
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787887
bogan scene? get a VL and do it up?
id say alot of the ethnic dudes are the ones bombing VLTs, and they are far from bogan!
in mild stockish form a R31 is perhaps a better daily driven street car, but when highly modified id go the VL Calais all day long!
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1787905
to me, someone who doesnt own a syline as of yet and a VL, i would have to say the reputation surrounding the VL is too much for me to handle consdiering buying one.
sure, they have sleeker lines that the R31, but as previously mentioned, the cops will hastle you like no tomorrow because the representation vl's are given is that your going to do something very stupid, very soon.
R31 to average commoner is a granny spec car. im still looking around as to what skyline i would like to get, but the 31 has a quieter name in the law circle, and considering i dont want to get told off constantly, i would go the skyline hands down...
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1797779
Hmm tough choice.
VL Turbos can me made to really fly, but at the end of they day they're a Holden. Plus as mentioned by a few ppl, you will get hassled in a VL, they have a rep, whereas R31s, most people just think its some old car.
Buy either based on condition.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/3/#findComment-1797816
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
