yeah my 1st car was a vl turbo calais,
if your comparing 4 door examples the vl has cleaner lines,
eg vl little bob tail boot compared to the box arse end of the 31
the calais has little trick features like half pop up lights etc
both 4 door examples handle shit anyways,
motors basically the same
both interiors are on par, (except calais versions much better)
more vls around
you will pat more for a vl
basically it comes down to what shape you like best
1 vote vl
vl calais (T3/4, custom plenum, huge cooler, dump,exhaust hsv17s on it hole sweeeeet)
^my 1st love hehe
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/4/#findComment-1797865
  • Replies 100
lol.. Forget about turbo he's not after turbo. If he was.. R32 or 180sx over the VLT is an easy choice.
Non-Turbo.
R31 in stock form is a more reliable and a slightly better performance package in all aspects. Chassis and acceleration.
Edited by Cubes
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/4/#findComment-1797887
go a vl man, evey point im gonna bring up has already bn said, plus they can look mean as with the right wheel(im sure thats also bn said) but the trade off is a holden that wants to be a nissan and be labelled a bogan....happy shopping!!!
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/4/#findComment-1798545
The R31 Ti Interior Owns the Calais interior
my mate had a Calais interior and shit was falling and breaking off all over the place, the window switches even fall out....
the r31 interior is just plain shitloads better....
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/4/#findComment-1798774
  • 3 weeks later...
Go the VL Calais there a beautiful car and when rebuilt run like a dream, RB30turbo with supra 5speed its a cheap reliable car. Plus are able to run reasonable boost putting out good power very fun. Leave out all the kits and crap. Had one that was hot house green over silver with 17" low profile perelli tyres just looked a treat. Will always look better than the R31 and perform pretty much the same.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/4/#findComment-1860954
Dude if it ain't a Turbo Calais forget it! Go the R31...
I just had my VL blow it's head- once again illustrating the issues with VL and the F**king radiator mounted lower than the engine!
I have spent about 2.5k just keeping it on the road in the last year and it goes and blows a head on me!
So- If it ain’t turbo go the R31- less hassle and less attention from the unwanted.
My 2cs as a forma VL owner
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/4/#findComment-1862593
:lol: Seriously any serious car enthusiast wouldn't buy a VL Calais if it wasn't turbo. Just cause your VL is a piece of shit doesnt make the ones the same.
And if you knew what you were doing you wouldnt be replacing the head with the standard head. For $2500 youd be close to gettng rb26head. The R31 and the VL are both over 18 years old so both will need attention to get them looking good again. The other good thing with the VL is there are a lot around for spare parts which you'll never have trouble finding. and when either car is finished, resprayed etc the VL looks ten fold better.
https://www.sau.com.au/forums/topic/98189-r31-or-vl/page/4/#findComment-1866713
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
