Who was it?
Who were the people who laid it all down on the line traveling where our street directories were of no use?
Who was the person who passed a message onto the waiter?
WHO WERE THE PEOPLE WHO OWNED TNS?????
It was us!!!!!!!!!!!!!!!!!!!!
Me and Frank!!!!!!!
plus our buddy Ric!
we had to send someone in who no one knew so you wouldnt have a clue what hit you
or your exhausts for that matter :P;)
Here is pictures from our wonder full yet scary trip up north!!!
http://boredofstudies.org/mark/tws/
OWNED!!!!!!
https://www.sau.com.au/forums/topic/9822-the-answer-every-body-wants-to-know/
  • Replies 141
ok in an early interveiw with TOSH, i scrambled some info on how the camp is still recovering from that fateful night.....
i wanted to get in quickly while the pot was still boiling and TNS are still scratching their heads in disbelief
here goes:
UR2EZ (8:46 AM) :
ok your thoughts and emotions :P
TaKaHaShIRyOsUkE (8:46 AM) :
1 thought: thank ****en god my car wasnt there :P
TaKaHaShIRyOsUkE (8:53 AM) :
"OH MY ****ING GOD. I CANNOT BELIEVE THIS"
UR2EZ (8:56 AM) :
BAHAHHAA so who took the slip
TaKaHaShIRyOsUkE (8:57 AM) :
Duncan
TaKaHaShIRyOsUkE (8:58 AM) :
he's just gone "you're joking!"
I saw Andrew glance at it and just go. "oh shit!!!!!"
TaKaHaShIRyOsUkE (8:54 AM) :
words really can't explain how I felt when I saw it. hahahahahahahahahahah that it the best I've evr seen
We even messed up TNS so bad they turned on their own...
TaKaHaShIRyOsUkE (8:52 AM) :
and all the guys were convinced that I was an insider who knew about it all along
They had no idea who it was, EXECUTION AND TIMING WERE PERFECT
TaKaHaShIRyOsUkE (8:50 AM) :
I was convinced it was Loz
Well this just inforces the fact that WESTSIDE IS DA BEST....
and to end the interview tosh had one last thing to say
man I still can't believe it
And at ^^^^ that moment we at TWS feel complete
We knew TNS would never be the same after sustaining such a blow as that....
signing out
TWS
Originally posted by jtir
ROFL
The exhaust even got fisted!!!!
YUP no holding back....
was a first for me aswell....
also after all that GIVING i need to TAKE aswell...
that four door line' gave me some good lubbin....
not as good as TWS lub... but hell any lub will do....
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
