Racial Voilence
Stel
 Share
Hey guys,
As all of you know there is alot of racial tension atm....(unless you live under a rock)
I got these photo's sent to me yesterday.
It apparently happened in Coogee yesterday, round 3ish.
I havnt seen anything about this on the news....coverup?
It must be related to the voilence...
Ive heard things like it was one of the Bra boys cars etc...
Anybody got any details?
  • Replies 129
I just got the email and it said "about an hour ago" and the time on it was nearly 8am today.
I got this email at 4.23pm yesterday...so it definately happened yesterday.
It looks like it was either around 8am or 3pm seeing as though there is a school kid on the road....
bra boys - group of surfies who come from maroubra.. local gang.. very agressive towards surfers not from that area.. - bra coming from maroubra.. just do a google search.. they'll show up i'm sure..
Edited by Links
Just got this in an email
You have all probably heard about the riots etc in Cronulla, We have
just
been warned as an Insurance Company for Motor Vehicles that the Ethnic
community are ready to retaliate and hit back at the Australian Race in
the
Parramatta Area. Today there were fights and attacks at Merrylands and
Granville.
Just all be careful and don't go anywhere by yourselves in that area.
They
are jumping out in front of cars to see what race you are then they
start
to hit the vehicle, even while you are inside. Do not stop for anybody
and
make sure your doors are locked especially at traffic lights.
All Insurance Companies do not cover acts of Terrorism and Racial Acts
resulting in Riots. So take extra care. They do however cover radom
acts
of violence by an unknown but you have to cover the excess.
 Share
    • Time for millspec wiring, MoTec electronics package, Bosch Motorsport ABS, let's goooooooo!!!   Maybe as @MBS206 suggested, just swap out those stupid blue relays near the ECU plug.
    • My only regret with the NC MX5 was no space for a spare, even a space saver doesn't fit in I do have a couple of those puncture repair spray cans, but if I get a large puncture, or sidewall damage, I'm screwed until a tilt tray turns up I'm thinking I might get one of those 4WD style of puncture repair kits that have that rope stuff and glue, whilst it will kill any hope of saving a tyre, it might help getting me out from some backwoods road far enough to find a actual tyre shop if the first can of tyre fix doesn't work I'm keen to see how your new toy pans out Uncle Duncan, I'll be moving to the Highlands next year, you'll need to shout out if your heading to Wakefield, whilst I've lost my balls for happy laps, I still love watching those that can
    • Yeah not sure what the warranty was, but it will be years outside it.  I've shot Link a message, will see what happens, I'm told their support is good. It is a plug in, so its a Link board in a factory case, very easy to access both sides of the circuit board by removing the top or bottom cover. To be fair the the Link, although I've checked to the factory connections and wiring specs, as we learned with Neil's car in the early days not all ECUs source power the same way. He'd been running a factory ECU with no trouble for years, but when we plugged a PowerFC in it wouldn't start up, just kept cycling power on and off. We worked out that the car was missing one of the 10a fuses "Electronic Parts", and to Neil's knowledge it had never been there. Turns out the ECU pulled its main power from that source not the same place the factory ECU did.  Point being....there are multiple battery and ECCS power sources in the factory ECU, and multiple grounds as well....not telling from the outside exactly what the Link uses (and doesn't use)
    • Now, thanks to sonicii, onto the uneven floor from a tyre sticking 100mm into the boot space. I looked into options to raise the floor to the level of the tyre, and ended up going Extruded Polystyrene (XPS). EPS is what I normally think of as polystyrene, the annoying tiny balls that get glued into a flat sheet but XPS is quite different, much firmer and doesn't crumble if you touch it with anything. I also looked at things like heavy duty seating foam but XPS seemed like the right way. I picked up 3x 1200x600x50 sheets for $40ea. Initially I was looking for 100mm sheets because I needed to make up a 100mm gap, but as it turned out 50mm was available, much easier to work with and made it simple to store the tools I used a simple 15cm foam cutter to make the shapes. With some practice I was able to make reasonably clean cuts but I don't think Clark Rubber are going to be calling me to offer a job. https://www.ebay.com.au/itm/405092315205?var=675175481574 First layer in place, 3 dimensions are tricky! Second layer in place, bringing it to level with the top of the spare Cutouts in the top layer for the tools With floor back in place, nice and flat with 100mm stolen but no real impact on usability
    • Sounds like a good idea to me moh
