R33 wheels with good pontenza tyers= $200
Turbo smart fuel cut defender= $30
R32 Turbo =$200
12" Sub Box cost $100 =$20
S13 insturment cluster surround=$10
stanard r32 suspension=$50 for all four
Moblie phone Nokia White one... forget model =$50
R32 air con tank thing = $50
Stock r32 manifold and dump pipe $30 for both
Might drop on prices... Just post up or PM me
Cheers
Sam Murray
https://www.sau.com.au/forums/topic/98284-stuff-for-sale/
pics of wheels
R32 Turbo =$200
Cheers
Sam Murray
https://www.sau.com.au/forums/topic/98284-stuff-for-sale/#findComment-1785970
Stock r33 wheels :) if you intrested come look... they are cheap as chips... :) cant be bothered taking picks... located in kingston....
where are you from?
Hi Sam, do you know what they tyre size is? and tread %??
Thanks!
https://www.sau.com.au/forums/topic/98284-stuff-for-sale/#findComment-1786135
hey champ :) um from memory they are 215 i think... tread on the front ones is good.... back ones not so good :) about 60% for the front and less than 10% for the back... can get good tyers put on them if your seriousally intrested for small cost :) like 20 bucks more :)
pontenza tyers are really grippy... you will be suprised in the difference they make in traction :) :)
https://www.sau.com.au/forums/topic/98284-stuff-for-sale/#findComment-1786264
    • Hey, guys, I’m hoping I can find answer here. I have already done some searching and asking around but still nothing.    I fitted an IC7 dash in my R32 GTR, and I got everything displaying on the dash except my high beams. I get input voltage and the high beams displaying in the dash when I pull the lever, but not when I fully engage the high beams. I spliced into the Red/Blue Beam+ wire in the black center connector from the cluster, but there is also a black Beam wire I think I need to use as well. The high beams still work. It’s just a matter of getting it to display on the dash.    Has anyone fully wired in their IC7 properly ? I would appreciate any guidance on this.    IMG_8835.mov
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
