well, if you can't deal with a little bit of squirming from the back of the car in 2nd gear corners, maybe you should consider something along the lines of lawn bowls to pass your time. :P
I'll take that over plough understeer on entry everytime! no way in hell that's going to help your laptimes!
btw, you should have been goign the other way with your pressures.
  • Replies 105
The important thing is to have a go & have some fun.  By the by, I don't have sump baffles & with cornering gees reaching into the 1.3 + range I have never had oil surge problems.  Just overfill the sump by about a litre.  Obviates the need for such an expensive modification for cars that only occassionally hit the track.
If you look at the sump design you will see that the threat of starvation is only too real in even hard road driving. I personally wouldn't do more than a few soft laps in an un-baffled GTR - a $10k engine rebuild is too stiffer pill for me to swollow!
Maybe just factor it in the next time you change the clutch, thats what I did. My sponsor BMS only charge $380 for the flash Tomei sump baffle.
well, if you can't deal with a little bit of squirming from the back of the car in 2nd gear corners, maybe you should consider something along the lines of lawn bowls to pass your time.  :)
The point is simple: With the HICAS removed the car understeered more on turn in. Which means the rear wheels were working in opposite phase...
Actually second gear corners is not where the problem lays. It is in third gear corners. If you think putting up with a bad handling car is a sign of having large bollocks then good luck to you. Personally I would rather fix the set up & get better lap times. Half the fun of owning a GT-R is improving the car & getting better lap times out of it.
I never said I was happy with the present amount of understeer mid corner. For the record since the SES at Wanneroo I have changed the springs & dampers & adjusted the roll bars to fix the problem. What it does show is that the handling of a car will vary immensely from circuit to circuit & even from day to day. The week previous the set up was fine (At another track) with no hint of the plough understeer that showed itself in the first set of laps at Wanneroo. I had to adjust the car - consequently the next set of three laps contained by best time for the day.
As for tyre pressure - as long as you are in the right ballpark less pressure gives a larger slip angle, all other thing being equal.
not a problem in 2nd gear corners? make up your mind. It hard having a sensible dicussion about something when one minute your complaining about the "plethora of second gear corners (My local circuit at Collie has two, the short course at Wanneroo has one, hillclimb courses usually have a couple) & slower speed third gear corners..." But I guess since your car handles differently everyday, it must be hard to figure out where the bloody problem is :)
next you'll be telling us leaning in your seat helps you go around corners...
Never said there was a problem in second gear corners. HICAS effect is more pronounced, but then again so is low speed understeer. The problem is more so on turn in to third gear corners - which is what I was talking about. I never did complain about 2nd gear corners - you said:
There wouldn't be too many corners on Australian racetracks where entry speed would be below about 80-90kph for any reasonably setup GTR on race rubber. You'd pretty much need hillclimbs for lower speed corners, and MtCotton is about as tight as they come.
I was simply pointing out that my local track had a couple. Not complaining, just pointing out the fact that they do exist - inded that they are not uncommon.
You are right - chasing set up is a pain in the arse. It is one of the reasons why cars that are good at one circuit may be rubbish at the next. It is also a good reason for having adjustable anti roll bars & for taking a tyre pressure gauge & a pump with you to the track. A higher grip circuit will often result in different handling characterisitcs to a lower grip one. That is why people soften their set ups when it is raining, or have to make adjustments between the morning and afternoon sessions. On a GT-R most people install more rear anti roll when the grip levels are higher.
Leaning in my seat doesn't help me go around corners - it was simply a reaction to the EVO in front of me having a massive tank slapper on the marbles/dirt because he was looking in his mirror instead of where he was going. Actually not fitting properly in my seat doesn't help much either - I only just fit in the car as it is.
Beer Baron - The only problem is the Tomei one look to cool to hide away!
yeah they are a nice little piece. though mine have been just sitting in the box for months it will be good to put them to use!
djr81. i have a question. How do you mount the camera? :)
key comment being "reasonably setup GTR on race rubber" - not a terminally understeering GTR that compromises corner entry speeds so drastically.
In my years of racing supersprints and hillclimbs, I've never had a car be good at one circuit and rubbish at the next. I disagree about the handling characteristics changing on surfaces with different grip levels. its just that the threshold of grip is lower, and any handling characterisics present in the car are exasperbated. ie, it will be easier to exceed the grip of the fronts on turn-in, it will be easier to exceed the grip of the rears powering out of the exit. the surface doesn't actually change the balance of the car. It may make it feel like the car is behaving differently to an inexperienced driver (especially if he doesn't really challenge the limits of the car in the dry on grippy surfaces/days), because the car is doing different things, but that's a perception rather than reality.
Yes soft setups work better in wet or lower grip conditions, and on slower circuits. Partly because it dulls the response of the chassis and partly because more weight trasfer can help in particular areas like traction out of corners in the wet. But even this is a bit misleading because you are really just compensating for the lost weight transfer that you get in those conditions due to the lower speeds and G forces. But even at State Champ level, there aren't too many teams that make setup changes from one track to another.
Edited by hrd-hr30
You are missing the point - a small change in cornering speed results in a large change in laterals gees. For example you need 5% more grip to take a corner at 82km/h as opposed to 80km/h. A 5% difference is very easilly felt. So even a terminally understeering (Even for the three laps on that run until I dialled it out) can get through the corners reasonably quickly.
As for different circuits requiring different suspension set ups - you will find it is mostly down to time, money and understanding that these things are not changed. The parameters for car set up are so multifarious that it can make it very difficult to have a gun set up for every track.
Different grip levels can fundamemtally change a cars handling characteristics. For one the suspension geometry will take on more acute angles, any non linear sprints/dampers/bushes/roll bars will behave differently, tyre loads will have their effect & loads will be transferred & apportioned differently between the two ends of the car. For example at lower grip levels you may need a larger roll couple differential front to rear than at larger grip levels. So, in short, different grip levels can markedly alter a cars handling, not merely exaggerate its traits.
Maybe I am the one that is exasperated (I think you meant exacerbated) because I get tired of people resorting to personal abuse (Inexperienced, should take up lawn bowls etc etc) when they run out of logical arguments. I thought the idea of the forum was to discuss things and try to add to peoples collective knowledge, not invent conspiracy theories when others disagree. :D
As for the camera I put another child restraint anchorage point in the parcel shelf & then made up a bracket to bolt the camera to. The bracket is to lift the camera above the rear seat cushion. You also need a spacer to make up the gap between the parcel shelf (The wood one) & the lower steel shelf. I can post a couple photos later if it would help.
yeah a couple of pics would be excellent.
cheers.
I found a photo of the bracket. You also need a bit of threaded rod to screw into the underside of your camera. I also place some rubber between the camera and the bracket to soak up a bit of vibration. The bolt in the bottom threads into a nut that I welded to the washer in the child restraint kit which in turn is rivetted to the steel parcel shelf. This stops everything falling apart when you want to take the bracket out.
Give us a yell if that doesn't make sufficient sense.
that looks good. I can probably make one out of some sheet metal we have lying around and just pinch the camera holding bolt out of a cheap tripod i have at home. thanks.
FFS, the lawn bowls comment was clearly a joke, and I never said you were an inexperienced driver. but really, there are not many drivers at club level who can actually drive their cars 10/10ths. And even fewer who understand what is going on with their car at the limit! And fewer again who would know how to improve the car.
conspiracy theory? sorry, you lost me...
It seems to me that you're the one who doesn't like being disagreed with. I'm over this thread - I got little to no sensible discussion about HICAS, after asking if anyone had any tech info on the system, all that came up was one or two photos, and I really don't care about your thoughts on handling and car setup enough to continue reading or discussing it with you.
You believe your car's handling is totally different wet to dry, track to track, and even day to day, and no-one is going to convince you otherwise. That's fine, continue believing that. i really don't care - its just another car/driver on the track I'll never have to worry about.
so enjoy your motorsport, and i hope next time you take the car out, its handling hasn't changed too much :D
Edited by hrd-hr30
Richard,
Just be careful drilling holes in the parcel shelf. There are approximately a bazillion wires under there for god alone knows what purpose. Best to remove it before getting too carried away with the drill. Also stick your head in the boot to find location. Mine is infront of the ATTESSA module.
Also, mine was made to 50mm in height. I would suggest making it a little taller to clear the seat back properly. You bring it forward to stop it fouling with the rear screen.
Cheers
Richard
No there aren't too many people at club level who push their cars 10/10ths. Doesn't mean you should dismiss everyones opinions, however.
You got some good input about HICAS but chose to disagree with all of it. For the record, the conspiracy theory bit related to your posts whereby you assumed that all the motoring journalists all failed to understand how the HICAS system worked. So you assumed they all got it wrong & that all the posted documents were wrong aswell.
As an aside, one of the fundamental difficulties with most engineering subjects (be it car set up or whatever) is that it takes a great deal of effort to publish results and that those results are applicable to a very narrow field. To such an extent that it is rarely done.
So take your bat & going home. Fair enough. Don't let the door hit you on the arse on the way out. (A joke, by the way) :D
yeah, i would look a bit silly drilling straight through the attessa computer.. lol i'm sure it's been done.
yep i think maybe another 5 or 10mm hight and possibly a little bit further forward would be good just to make sure the camera i have wont touch the screen.
that's not why i dismissed your opinions.
I got alot of "this is what I think HICAS does", this is what I feel HICAS doing on the racetrack", and 2 pictures as the only technical evidence - one of which clearly shows that HICAS does not always counter-steer on turn in as everyone always says it does.
Considering that the journos (or the Aust media rep, before explaining it to the journos) probably got it from Japanese engineers, I think there is a high chance that the explanation was misunderstood/misinterpreted. hardly a conspiracy theory.
jokes are supposed to show some sort of humour - ie to be amusing... I suppose the meaning of this comment of your changes like your car's handling, because today it doesn't seem intended to get a laugh...
Anyway, I'm about to get my hands on a R32 GTR and also plan to take it to the track for track days but not for any competative use, similar to the original post.
I thought I would post up a stack of questions but the search functions have answered about 90% of all my questions so far.
The R32 I'm about to get already has:
Metal turbine blades instead of ceramic
Nismo exhaust from the turbos
Nismo fuel pressure regulator
Nismo grounding kit
Adjustable dampers
Twin plate clutch
4 core aluminium radiator.
The following things are the parts I want to install not just for performance but for reliability also:
Torque Split Controller
Boxed-in Ram Pod
Aftermarket ECU
Front & rear sway bars
Oil cooler
Baffled sump kit
HICAS lock kit
Camber pins
Master cylinder brake bracket
Braided brake lines
Either DBA 5000's and track pads or
CSC Caliper kit.
Some questions:
Do I need to consider a better fuel pump or is the standard one good enough?
Is 16psi OK to run with this setup?
Do you need to drop the gearbox to fit the baffled sump kit or is it actually easier than that?
Are there benefits or pitfalls in replacing the engine driven radiator to a thermo electric fan?
Any of these things a waste of time?
Anything that I should consider that I haven't listed?
My opinions on the discussion so far:
I would go for locking the HICAS just to stop any of the unpredictability that so many experience. Didn't the Winfield Skylines lock theres?
Being involved in other car clubs, I found the guys that run at 10/10ths going for sheep stations always had very different suspension set-ups for each track. In NSW Oran Park, Eastern Creek and Wakefield are such different tracks which resulted with different bump and rebound rates, different ride heights, different sway bar settings, and particularly different alignment settings. When the difference between 1st and 3rd was less than half a second in each category suspension was vital. Particularly in the completely standard class where alignment settings were the only thing you could change apart from the compulsory safety modifications.
It's possible to generally set up a car to be good allround at any circuit but it won't be it's absolute best. Tracks change because there are so many variables. The last time it rained, how much rubber on the track, whether it's hot, cold, barometric pressure, etc. Depends what your chasing. To be the best or competing just for fun?
Some questions:
Stadard one is ok if your AFR's are ok on the dyno. Just turn up with a full tank.
Maybe, see previous answer.
Not 100% sure, but I believe it is harder than that. Remember you have a drive shaft running through your sump & a subframe holding the whole shebang up.
Slight gain in power, not worth messing around with.
Worry about temperatures of everything - but mostly your engine & your brakes.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
