  STOCKGTR said:
I am having big blow by problems on the track also. None through the dipstick, just through the breathers. I fill the ARC catch can in 4 laps. :wub:
My oil pump is stock...I think??? I never replaced it. So I am a bit weiry to add an extra 1 lt of oil.
Will the trust sump extension kit with baffle and pick up reduce my blow by?
Has anyone used the Mines Rocket Cover Baffle Kit?
I need help I hate having this problem at the track, it gets VERY messy :laugh:
Anyone?? :(
all feedback appreciated
  • Replies 105
NO.
I have seen this happen to a few cars now. Mostly it is related to having too much oil in the head of the motor & it overwhelming your catch can. Sometimes it is dependent on whether a circuit is clockwise or anticlockwise - people can have problems if their catch can is on the passenger side & the circuit is anticlockwise.
Have you plumbed the can back into the sump?
NO.
No, The catch can is the ARC one which sits on the front drivers side. It gets the blow by vis one braided hose coming from the rocker cover. I'm thinking the mines cam cover tripple baffle plate will help reduce the blow by????
Any thoughts....anyone?
I've thought about the possibility or re-directing the oil back into the engine (sump return)... would stop the sump from running dry.
I read somewhere the fables gibson gtr's did this. Of course, this means that fuel gets into the oil (right?), and regular oil changes will be needed...
I don't know if its a good idea for a street car, but on the track, you could do it (put a tap into it).
blow by is mostly caused because the piston rings arn't a perfect seal (and when they do, the engine siezes), right? So less boost (less cylinder pressure) would help.
baffle plates help prevent oil starvation (air near the pickup), so I understand with my highly practical theoretical background... bigger sump means more oil reserve (less % of oil for same abount of blow by & oil burn).
umm, yeah.
ebola
yes an additional drain from the head to the sump can help with too much oil in the head. Sydneykid has posted a detailed thread about oil control in rb engines.
Also re the mines baffles, I haven't seen those in particular but there are standard baffles in the cam covers and I have also seen foam used - just like a catch can it is designed to catch oil suspended in air before it goes out the engine breathers...then it drains back into the sump.
The trust sump won't help with blowby but it would help keep your bottom end healthy on the track.
  • 6 months later...
To those adding the extra litre of oil just curious as to wether u leave it in there after a track day (or are u refering to track only cars) or do u change oil straight away after track days an just run normal ammount or what , Just curious. Asked the mechanic who has been tuning my line and he looked at me like I was mad an said not to bother, maybe becaus it was my first track day and on street tyres so he figured Maximum G's were not gonna be a problem. :P
he's probably right, but it is cheap insurance isn't it?
No problem leaving the extra litre in there, and depending on how hard and hot you run it you should probably dump the oil anyway.
The way I understand it, is that if there is an extra litre in there then it will increase oil pressure, thus creating more blow by?????
True. I found that I got a lot of blow by until it settled at Full. But then I would top it back up and start again, becuase it's always better to have lots of blow by than to have spun bearings.
So even if I had a catch can oil cooler relocator (ie extra capacity and cooling effect) would the extra litre be justified still if I didnt have oil retrictors fitted in the heads. Somewhat concerned about the aditional oil pressure created by the extra oil and possibility of blowing seals in turbo or engine due to it.
At the risk of widening the conversation, I'm keen to get my car on the track and it is pretty much stock engine wise (Apexi intake, cat back exhaust). I'm pretty sure to begin with it is more than fast enough for my driving skills so have started putting $$$ into upgrading brakes first and looking at tires and suspension next.
I'm hearing you guys talk about oils coolers, sump baffles, etc. From an engine standpoint, if I want to track my GTR, what would you invest in part wise what to make sure at the end of the day you can run hard and not toast the motor. I'm looking to building a solid, reliable car that I can crank up the power on as my driving skills improve.
Get at least a 19row oil cooler installed and add a litre of good oil. I suggest Castrol Full Synth 10W/60 - "For race proven competition engine" or some marketing talk like that on the bottle
No Melbourne stockish GTR's have had any oil related engine issues on track with the theory above.
Oil pressure is a good thing. Honestly I don't think you will get enought pressure to cause damage.
Catch can and oil coolers are two seperate things, which I think you know but wasn't clear from that sentance above. But yeah we have been 'advised' to still add a litre or till it's above the 'F' on dip stick
The problems that I have seen are not usually guys with GTR’s on their first day out, but after they have had a couple of outings. They fit some sticky tyres, get the suspension set up, some decent rotors, brake fluid and pads and start to learn the fast way around a track. Then the oil surge problem raises its ugly head, mostly the engines are fairly standard, boost up, exhaust etc. They start using higher rpm more consistently, generating higher G forces both round corners and with later/ heavier braking and acceleration.
The problem is the more consistent higher rpm moves more oil into the cam covers which doesn’t have time to drain back into the sump. The higher G forces further slow down that draining, particularly cornering and braking. Plus they cause the oil to move away form the oil pick up in the sump. It only takes a few revolutions of the crankshaft to cause bearing failure. At 6,000 rpm, 6 crankshaft revolutions takes 0.06 secs, you won’t even notice that on the oil pressure gauge, especially mid corner.
An oil cooler will not help you with oil surge, however it will help keep the oil temperature within a decent operating range. An extra litre won’t do it either, more like a 3 litre overfill would be necessary. But then the spinning crank would hit the oil when there weren’t any G forces to move it away. That is both bad for the crank (impact) and the oil, whipping it into a foamy mess that is not good for lubrication.
So my advice to guys with GTR’s is, sticky tyres and upgraded suspension = a sump with baffles, wings and one way doors.
:) cheers :)
  r33_racer said:
And anyone who knows anything will believe that except anyone in mexico....funny hey.
I know nothing so perhaps thats why. :)
I hate to admit it but as a rule Vic has the quickest GTRs around with a high std of driver in them. (how else tcan they be so quick)
A few of them have been very quick on std motors until they got power hungry. Some slapped turbos on std motors, some built motors as well. The only GTRs that have let go have been old tired std engines with T78s slapped on the side. No real surprise.
So whilst i agree that if your engine is out then its a good idea to do the sump etc. But GTR owners that wrap their cars up in cotton wool because their motors are std are missing out on the fun.
I question anyone in the country that can build/tune cars as well as Vics leading few workshops....so whilst i believe what SK posted...i believe its bordering on the little too conservative side :laugh:
yeh i dont know anything either...i only race a lowly gtst...how could i or other like me compare to the godly gtr drivers. There arent too many quick ones up here..apart from Giant ofcourse.
I guess we can only go on experience. And what we see is exactly what Scotsman/Roy posted.
The Stock GTR is a pretty good package, if it really is stock then i'd probably just add an Oil cooler and you should be fine to go have some fun. But listen to what SK said, that if you start to do more go-faster mods, don't forget about the safety mods....
Yeh i was only taking the piss in what i originally said. But its strange how down south there you guys dont run into those problems...i dont know about nsw but it happens here. Doesnt just apply to gtr's either.
Sill question? Which side of the sump is the GTR pickup?
There are quick left and right handers in Vic so if its a problem i would have thought it would have shown up at places like PI.
Strange...the only thing i can think of is the fact that Vic guys overfill their engines...others dont. I know Dave (The R32 with a T04Z on a std engine in Syd) overfill and he is kicking.
But meh, me a lowly GTSt driver as well. GTRs guys with all their talk of diffs, brakes and sump baffles... its like using a bobcat to pick your nose :D
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
