well I'm with you r33 racer I don't know why they haven't had much trouble either. Been plenty of oil surge and bearing problems in nsw.
Anyway we've had to put standard sumps with internal baffles on for targa instead of the extended ones we normally run, and at Eastern Creek yesterday I was getting surge in 10/11/12, enough for pressure to drop from 6 to 4 even with overfilled oil on the expensive new oil pressure gauge. Standard one didn't show any variance.
But anyway.....since putting a big sump on a gtr is an engine out job, I would suggest just throw on a big oil cooler, head out and enjoy yourself and start saving for the rebuild.
When it blows - head over to Syndeykid's oil control thread and do all that stuff while it is out - it is the result of years of development and only costs a few extra $$$ when the engine is already apart.
  • Replies 105
Corners 10/11/12, that's the right kink and double left onto the main straight isn't it?
If so, that's a hard acceleration run out of the hairpin in 2nd gear, change to 3rd and then to 4th. Flick right, brake hard and change down to 3rd. Hold 3rd through the long, double apex, left hander.
If anywhere is going cause oil surge it is that sequence, it has all the ingredients;
High rpm straight from a low gear (oil build up in the cylinder head)
Sustained acceleration G force (oil flowing rearwards in the sump, away from the pick up at the front)
Followed by heavy braking G force (oil flow away from the larger oil returns in the cylinder head)
Flick change of direction, then a sustained rpm and G force, double apex corner (oil flow across the sump)
That’s prime oil surge territory for a GTR sump.
:laugh: cheers :w00t:
Looks like us Mexicans are lucky when it comes to oil surge.. :laugh:
My car had a standard sump, although it did have a built motor from Racepace.
Even 350rwkws, RE55S tyres, decent brakes and suspension at the time, again with 1 litre overfill on a standard sump..
But I would recommend getting some sort of sump baffles if you were rebuilding your engine, cheap insurance.... :D
And Roy, stop grovelling on about your RWD 2 Litre and start putting out some numbers!!! :D
And Roy, stop grovelling on about your RWD 2 Litre and start putting out some numbers!!! :happy:
Numbers? Me or my car will never do any decent times. That’s why I have to talk it up so much, using quotes from my soon to be released book “Excuses for being inept and coming last”
Get at least a 19row oil cooler installed and add a litre of good oil.
In looking at oil coolers, some talk about a thermostat
from HKS
Thermostat controls Oil Temperature
As HKS oil cooler uses special core that is excellent for cooling purpose, this oil cooler has thermostat to prevent overcool (except for some models). This thermostat is very good at responding to temperature change and also acts as relief valve. When engine oil gets hotter than thermostat temperature setting (70C 3C), it will run into oil cooler core and be cooled down. When engine oil is cooler than above temperature, it will bypass the core and keep oil temperature in best condition. By acting thermostat as relief valve, HKS considered safety in an emergency.
Is this a significant benefit over a more basic version like the one offered by Just Jap?
http://www.justjap.com/parts_ncooling.htm
The JJR coolers look like pretty good value
I've just bought a Trust oil cooler. My mechanic said that the lines have to be adleast dash 8, prefurably dash 10. And from what I found, all the kits with dash 10+ lines cost heaps (Jap kits, and the big UAS kit). But i'm not sure what size lines the just jap kits have.
Edited by sav man
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
