i have been told by a performance place that when putting in rx7 550cc injectors i still require a resistor pack however i thaught that was only for low impedence injectors as rb20 is high, the rx7 ones are also high so will these fit in without to much hassle????
Secondly what is the correct part number?
Last if i install them myself can i drive to a dyno(its pretty far though) i dont have a luxuary of a powerfc but i do have a remap ecu i just need to et tunned once are in?
thankyou :(
https://www.sau.com.au/forums/topic/98328-rx7-series-5-injectors-into-rb20det/
yes. if they have a bosch(square plug) there s4 low impedance
if they have a denso (oval plug) there s5, both are reddy pink.
i thought 20s had a droping resister. factory ones are low impedance any way arnt they?
I would talk to your ROM tuner first, cause I bet they wouldn't recommend the 550cc. And if they do they obviously havn't tuned on them before. Both my boss and I have had trouble with those injectors when tuning factory ECU and I also know that Martin Donnan had the same problems down south, very shite low pulse width control. Rotories dont care because they just drink fuel.
I also agree with rob82 comments as Matt Spry tried tuning them for my last R32 with factory ECU remap and had the same problems. Took them out.
Cheers
I'm running these red tops on my r32 with a remap and they work fine other than a rough idle.
This could be rectified with a bit of messing around with the ecu idle control values but I havent really had much time to do it yet.
wat kind of power can you make before these injectors start to run out of flow?
I think they flow to about 560cc each From memory so about 560HP@flywheel?
As long as the fuel pump is up to the task of course.
well my tuner is not recommeending these as too much mucking around, well a question for u all i have asked red drifter thanks for ur help but, my prob is at the moment car is so shitty off the line after remap i got a fmic,14psi( can xtract ne more with out fuel), hiflowed t3, xhaust,malpassi rising fuel reg, big fuel pump and all the other usualls, would i be better off getting a proper engine management or these injectors to cranck up the boost
GTR injectors (444cc's) are the most common upgrade, you just need to get a GTR ballast resistor pack to go with them. They flow enough to reach the limit of standard RB20DET internals. The Standard ECU (remapped) won't have any problem running them.
:) cheers ;)
Edited by Sydneykid
after a tough choice i thuaght i have heard too many bad stories with the rx7 injectors so i got hks550cc ones(alot more pricey) instead lets hope all goes well. pppft i doubt it
Are they HKS 550cc's injectors for an RB26 or for an RB20?
:) cheers ;)
S5 inj + PFC work fine.
However @ idle even tho it doesnt sound to bad except for the ocassional pop they need to be tune quite rich AFR.
The spray pattern on Rx7 inj is more like a squirt rather than a mist compared to a piston injector so tunnig for them to spray small amounts of fuel(@ idle) its kinda tricky. And hence requires the AFR to be slightly rich. My AFR @ idle was ~ 12.0 when they are usually around 14.0.
Rotaries have a deflector which splits the spray in half for a more even distribution, obviously piston motors dont have these.
Best bet is to go for GTR inj. or if budget allows go for SARD, HKS...
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
