Boost cut?
Just a theory: When you are at a constant 5000rpm the turbo is well on boost, then the jab of the throttle causes the turbo to spike, engaging the ecu to activate the boost cut. Not sure if i am just spinning shit :lol:, but i have also felt that if i keep the revs at 4000rpm, in 2nd, then poke the throttle, the response is so much greater and the arse end steps out harder. I do not have any problems though, but my car is not exactly standard :(.
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1787171
Isn't the proper term fuel cut?...and as to why the car might be missing...there could be several reasons...the plugs could be F##ked or the gap might be too big...when running higher boost...its always a good idea to have the plugs regapped to 0.8mm...i'd reckon this should be the first thing to check...good luck...
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1787709
You may be hitting the fuel cut circuit in the ecu, just wtch your boost gauge and see whats happening without crashing :angry:
We had an R32RB20DET on dyno last week which kind of had the same problem. Ended up being ignition coils on 2 cylinders. They looked cooked around the sealed solid resin area. Check it out
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1788070
Hey Turbine do you know where you can get your coils tested for free ???
You could do this yourself. Check the manual it should tell you how to test them. I dont run the standard nissan coils in my 20 so I cant help much their.
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1788706
Sorry guys should have gave more info. I'm running bcpr6es NGK's which are gapped at 0.8 (be lucky to have done 1000klms on them) and i'm running F.E.T high capacity coil packs...
I'm thinking boost/fuel cut.... Just never came to my mind until someone mentioned it up there /\....
Gonna remove the boost T, and also going for a run with my mates air/fuel wideban meter to check the mixture this evening..
Only thing is, my wastegate runs 13psi stock, i installed the boost T wound all the way out to try and bring on boost sooner but keep the 13psi boost. I did think that it would prob creep to 14psi etc. I'll let you all know how i go anyway, many thanks for the ideas!!!
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1788954
Well i would think that it is not called fuel cut either, as the last thing a manufacturer would do is lean the fuel mixtures at high rpm.
ECU detects high boost level and cuts the ignition, so technically it is an ignition cut :lol: :)
Read the first post carefully:
When going through the gears normally my car boosts fine with no hiccups. But tonight i tried staying in high revs in 2nd at a constant rpm (lets say 5000rpm) then flooring it and the car started missing. It only does it when i do this?
Any ideas or suggestions?
Cheers
Jayson
Fault does not occur until he keeps the revs at a certain rpm, then pokes the throttle. If it was plugs or coils, the spark would break down when he is driving the car hard, not only when using this techneque.
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1790156
they dont lean the engine fuel mixtures out at hi rpm the ecu cuts the power to the injectors so there is no fuel to burn that why its called fuel cut
are u sure its not pre ignition
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1790327
like someone above mentioned, it only happens when holding the car in high revs then stepping on it.. This causes a massive surge of boost/fuel as the turbo is in it's prime ready to boost and it was casuing boost/fuel/ignition cut or whatever it is.
Basically... removed the bleed valve, problem sorted now.. WHich is farken awesome as now i can drift it at Sunday's drift day!!! yey
But with a bit less power ;)
Thanks for all your info and advice
Edited by Mase
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1791445
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
