im a bit curious to exactly how these laws work.
i hear if u get ur Ps in QLD or SA there are no car restrictions.
does this only apply if u live there or only if u get ur licience there.
and can u upgrade from a VIC L to a QLD or SA P?
thanks guys
https://www.sau.com.au/forums/topic/98380-p-licience-laws/
aint da same down here in VIC.
theres alot of restrictions on wat u can drive and stuff, real crap.
wat do u mean i have to ring QLD transport?
i herd i can pretend to live in QLD or SA by putting a relitives postcode as a reference or something.
is dat possible?
https://www.sau.com.au/forums/topic/98380-p-licience-laws/#findComment-1787852
Well just off the top of my head I can think of a few problems:
You would have to do your test in Queensland. If you did it in Victoria, then to apply for a qld licence, you would have to go into a qld transport office to fill in the appropriate paper work.
You would have to convince them you are a Queenslander, with evidence of where you live. you can't just put down a postcode, you need a full address.
Your Drivers Licence is your main form of ID. You need to show it when you do anything important with anybody (Gov. agency, bank, etc.). Which would mean you are a Queenslander to them.
I'm not sure how you would get registration for a car in Victoria when you have a Queensland licence. Or insurance for that matter, considering your licence says you live somewhere other than where the car is kept. Could cause problems.
These are just things off the top of my head. In short it is near impossible. Don't bother even thinking about it.
https://www.sau.com.au/forums/topic/98380-p-licience-laws/#findComment-1787940
i think QLD transport is thinking of doing the same thing pretty soon. for those who have got their Ps, its not gonna be a problem. BUT if u get it after they bring in the restriction, it would be pretty tough.
So i would say give QLD transport a call and find out what u need to obtain a QLD drivers license. Im pretty sure u do need a residential address as u have to prove u live here.
https://www.sau.com.au/forums/topic/98380-p-licience-laws/#findComment-1787957
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
