gun metal grey with SDU sticker spotted at barrys dyno tune
Slap it and say it ain't going no where, you'll be fine.
So the whole rb25de neo setup was a tiptronic setup and i swapped everything over to my rb20de neo setup and yes even the cluster of the rb25 was swapped over.
By DraftySquash · Posted
and I thought size mattered 😝 At this point I may either pray to the Afterpay gods and get a torque wrench or attach a water bucket to the breaker bar. I appreciate the help though 🙏🏾 -
Or get a guy in his early fiftys to do it. A single good "oof" and about two cracks from his lower back is about the right tightness...
It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
