Hi fellas
Im in the market for the boost controller and would like to hear your thoughts.
What do you recknon is the one that stands out appart from apexi.I was having a look at Blitz SBC Spec S which is single solenoid boosting upto 1.2 bars. Seems very good, the down side is being a single solenoid.If you've got any suggestions please advise me of it
Thank you
https://www.sau.com.au/forums/topic/98407-new-boost-controller/
I recommend the GReddy Profec B-Spec II.
The cheapest JDM EBC and it holds boost well. Comes with bells & whistles such as peak boost recording, gain settings, real-time boost reading (like a digital boost gauge).
However it is only single solenoid. Shouldn't be a problem unless you're going to be running huge PSI.
i run a Blitz SBC-iD, holds up to 2.5bar and it's dual solenoid.
So far have had no issues what-so-ever and it mounts very nicely in an R32 ashtray to keep prying eyes in the dark. Kind of nice that it has so many options and that you can pick them up used for about 300$
I bought it because everything in my car must be controllable from the interior and a manual boost controller doesnt offer that. It's a wonderful little toy purely because of that feature alone.
more info here...
Blitz SBC-iD
Hi fellas
Thank you
Don't know from experience, but I've heard good things about the dual solenoid version of the one you're talking about. Blitz SBC Spec R. Autobarn have them retailing for $799, and the Spec S for $599, but I know you can get the Spec R (dual) delivered for $500 if you do your research :)
    • Does anyone sell a pipe that's made to go from the Greddy FMIC kit for ECR33 (RB25DET) to the Greddy intake manifold?
    • Not that I know from experience, but in theory you'd want your gate spring to be as close to target pressure as possible, so you'd go with the higher gate spring?
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
