Hi fellas
Im in the market for the boost controller and would like to hear your thoughts.
What do you recknon is the one that stands out appart from apexi.I was having a look at Blitz SBC Spec S which is single solenoid boosting upto 1.2 bars. Seems very good, the down side is being a single solenoid.If you've got any suggestions please advise me of it
Thank you
https://www.sau.com.au/forums/topic/98407-new-boost-controller/
I recommend the GReddy Profec B-Spec II.
The cheapest JDM EBC and it holds boost well. Comes with bells & whistles such as peak boost recording, gain settings, real-time boost reading (like a digital boost gauge).
However it is only single solenoid. Shouldn't be a problem unless you're going to be running huge PSI.
i run a Blitz SBC-iD, holds up to 2.5bar and it's dual solenoid.
So far have had no issues what-so-ever and it mounts very nicely in an R32 ashtray to keep prying eyes in the dark. Kind of nice that it has so many options and that you can pick them up used for about 300$
I bought it because everything in my car must be controllable from the interior and a manual boost controller doesnt offer that. It's a wonderful little toy purely because of that feature alone.
more info here...
Blitz SBC-iD
Hi fellas
Thank you
Don't know from experience, but I've heard good things about the dual solenoid version of the one you're talking about. Blitz SBC Spec R. Autobarn have them retailing for $799, and the Spec S for $599, but I know you can get the Spec R (dual) delivered for $500 if you do your research :)
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
