I am aware that fitting say a 3.5 inch exaust and airfilters to my stock GTR will increase power, and most likely fuel economy..
however will this increase in power be potentially damaging to the engine or is it just a good thing all round.
https://www.sau.com.au/forums/topic/98411-can-an-bigger-exhaust-be-bad/
thanks guys,
just wanted to make sure, dont really need the extra performance although it would be nice, just thought it would be better to improve the economy and dont want it to blow up on me.
i drive the GTR for work every so i put alot of miles on it.
thanks for the info.
I didn't really get any better economy. If you do a lot of kms make sure you select a quiet exhaust...I have a kakimoto which is pretty quiet. Good to free up the exhaust though otherwise any other performance bits or boost increase you are not getting the full benefit of.
It my understanding that a bigger exhaust is better for top end, but can lose power at low revs (no backpressure).
So just don't go sticking a 5in exhaust on, and you should be fine. 3.5in should be dandy
I heard that with turbo's you don't need to worry about backpressure? I don't understand how or why? or even what the deal is with backpressure.. maybe someone could explain that... but that's what i've heard
Good point.
*now* I remember, the less restriction after the turbo the better.
but as low rpm, would the turbos provide enough of a restriction? Or it is just that as soon as boost starts to kick in, there is more than enough exhaust...
ideas?
Gasses only flow because of pressure differentials. If you have too much back pressure in the exhaust system, then the exhaust gasses aren't going to flow as readily through the turbine. Then the turbine doesn't spin as fast, and you don't get as much boost pressure.
the engine is pretty strong by itself, will last a long time on low power if looked after. Be More worried about the turbos letting go, if you want to be safe .8bar should be fine, if you want a bit more power a lot of guys run std turbos on 1bar fine.
Remember, the candle that burns twice as bright, burns half as long.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
