All the SCOOP on SWOOP!!!!
  • Replies 143
Guest Austin Powers
haha. I started this thread and I'm surprise it's still going. What happened to DR GTR. He seemed to have been chummy with SWOOP over at Team Evade. Regardless what his real name is, I'm sure he will respond to SWOOP or just do what most Viet do....Scream out, "Ay mate! what YOU NAM"
When is the next cruize anyway, speaking of which?
Originally posted by Austin Powers
Hey, that's Valentine's Day Ed, I assume you don't currently have a regular root, otherwise there's no way in hell she would let you out on that day. haha.
Where the hell is the rock anyway?
:bahaha:
I do have a regular root, ask your mum :uh-huh:
haha.
So you're the "5 Sec GUY" she mentioned the other day.
Lets not drag our mums into this discussion ok? I don't kiss and tell when I take your mum up the arse. :D
hahaha...so that's why I hear our German Shepard howling at night :lol:
Leave my dog alone!
the 5 sec guy must've been your dad b'cos I'm the 6 second guy :uh-huh:
hahaha, well since I live by myself, whoelse could it be? Next door neighbours cat?! :eek:
eric: hahaha, but you were talking about how your neighbours, cousin's brother's habbi's dog was really tight just then on ICQ!!! :D
ok that's enough for today...I'm spent :lol:
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
