All the SCOOP on SWOOP!!!!
Guest Austin Powers
Na, don't want to go to Minh's. Might catch him in an uncompromising position with SWOOP. Jusk Joking Dr, put away those Pecs.
Ed, what you done to your car man? I mean looks sweet with the black bonnet and all but what's under the carbon fibre bonnet?
  • Replies 143
It's all looks.... :lol:
RICE BOI :)
well not for much longer....
i hope
Guest Austin Powers
Dr GTR, me real name is Viet and me last name is Cong, but I aint no VC man, honest, I was born in the south....you can call me Austin, that's good enough.
Imagine if me get the number plate "VC". You think I would be shot in Cab or what? It would look sik on my Echo....NOT!!!
Originally posted by diduc
if you want to catch SWOOP, he's usually driving along gipps st towards cabra between 7.30 and 8.00am and around 5pm cos I see him most weekdays. So I suggest you take a camera and sit on gipps between Horsley Dr & Polding St on LHS
hehehe, who is the stalker? :lol:
You don't know him do you?
NISSAN SKYLINE R34 GTR V SPEC 1999 6 Speed MANUAL BLACK 14000 $138000 N/A
Description: 4WD V SPEC, FULL NISMO BODY KIT, Twin Air Bag, Power Steering, Power Windows, CARBON FIBRE Power Aero Mirrors,Central Locking, Climate Control Air Conditioning, HKS Exhaust, HKS GT Front Mount Intercooler, NISMO 320 Klms Instruments, R34 GTR V SPEC 11 NUR Badging, APEXi AVC-R, HKS Rev/speed Limiter, G Tech Performance Meter, Full double din DVD/TV/MP3 Entertainment system, Black on gold NSW number plates SWOOP, Registration, Warranty. " THE NISMO BODY KIT BEAUTIFULLY ENHANCES THIS AWESOME PERFORMANCE VEHICLE. ALL PERFORMANCE PARTS FITTED NEW IN AUSTRALIA BY POWERPLAY IMPORTS "
is this the one?
Guest Austin Powers
hmmm, looks like he's selling it? Sounds like the right car too. Must be a damn good car to ask $138k for it...but look at all the bells and whistles. Perhaps I can trade my Echo in for SWOOP's GTR. This guy changes his car more often than I change my undies, but lets not get into my hygiene habbits. He only had it like few months....maybe he's getting a Lamborghinni??????????????
Guest Austin Powers
Easily afford my arse. Most of us are still at uni. What you'r trying to advertise Jim. We know how prosperion works. There is no way Prosperion will approve any of us for a GTR R34. It's $100k plus. If you think GTR R34 is "easily afford", why de hell are you driving a R33 GTST? :)
:) :Owned: :bonk:
To tell you the truth, the 34 GTR doesn't cost quite as much as you think ... both in terms of initial vehicle cost or weekly cost.
I'd approve you all on R34 GTR's if I could ... unfortunately our financier may think otherwise :)
I drive my baby b'cause I'd rather not kill myself before the 350Z comes out. Considering before the 33GST-t I'd only driven a Peugot and a Hiace and I'm still on my P's (damn 3 years !!), it would seem a little irrasponsible to rush into too much power. I'll only have my R33 for another year and a half, after that I'd say an R34 would certainly be one of a few options I'm looking over.
I have a Silver R34 Mini-Z in the meantime if that counts ? Hehehe, just practising for the future :lol:
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
