It's been like 2 - 3 weeks now with no Ultimate. I've had to use some Synergy 98 & Optimax.
I want Ultimate again! Anybody who always uses ultimate but is having to use another fuel feeling the difference? speak up.
I think Optimax has been slower, 3rd gear 12psi just isn't pulling as quick I think.
https://www.sau.com.au/forums/topic/98459-bp-ultimate/
I have been using vortex98 for the last few tanks and fuel economy is exactly the same.
The car does pull harder in 2nd and 3rd!!
I was suprised but my car runs better on vortex98 than ultimate or optimax.
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1789549
I'm of the understanding that most of the east coast has got an Ultimate shortage, with stocks to be restored at the end of December or early January.
I've been giving Synergy 8000 a go, I'm on my 3rd or 4th tank, I've noticed that power seems to be ever so slightly up, though my fuel economy has dropped slightly.
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1789694
yep, there's been none in my town for at least 3 weeks (2 BP's, both out).
is really beggining to sh*t me cos i gotta drive 15 mins down the road to get optimax, or remember to fill up when im passing a shell/mobil out of town.
tried vortex and wasn't real keen, my knock levels went higher than i've ever seen them (although was a warmish day and car is tuned for ultimate).
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1791718
Well ive been running on synergy 8000 and recently swapped to optimax extreme.. and as far as im concerned it kills bp ultimate. I've got noticable power differences, specially after re-setting the ecu.
Though will good to be back to ultimate again, no ethanol or anything to worry about:)
Dayne
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1793330
i think the "Ultimate" part in BP ultimate's name has a lot of people fooled lol
I think you'll find most workshops agree you can tune the hardest on Ultimate for any pump 98 fuel in Aust.
#1 Ultimate
#2 Synergy 8000
#3 Optimax
Some people say Synergy is a tad better than Ultimate but usually Ultimate is the prefered fuel for tuners trying to get the most outa it. I got the most power & lowest knock out of my car tuned on Ultimate.
Edited by geno8r
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1793466
how do you go about resetting the ECU?
Disconnect the battery, press the brake pedal to drain all the remaining power. Maybe leave it for a while then just hook the battery back up.
And I've been using Optimax since they went out of Ultimate and to be honest there is no difference at all imo. :(
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1794029
i ran my car on ultimate all the time and i found it pulled harder, had better economy and ran better, less lumpy in the idle. Using vortex and sh*t like that made my car crap, noticed it clutch kicking at pt.g last week.
GO BP ULTIMATE!!!!!!!! please come back to me
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1794053
Sounds like you guys over east are just getting what we went through over here about a month ago. The refinery had a problem so they couldn't produce anything but normal unleaded, so most stations were without 98 for a few weeks. Over east was still ok because they stockpile it I guess. Now that it's normal over here, that was probably the priority so all the fuel has probably came to us. :)
It won't be too long I imagine. Unless there are BP refinery's over east, I would think there would be which would mean I'm babbling shit.
You lot are complaining but over here Ultimate is the only 98 fuel we can get so it hurt us a LOT more!!!
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1794884
Ultimate is more expensive than extreme 100 here in QLD... On any given day BP is at least 2 cents dearer than shell at aspley and virgina....
So i stopped going to get fuel from BP along time ago...
I had the fc tuned on optimax and found extreme to knock a bit more but the extra 50km;s per tank has not rally made me a fan... ill stick to 98 plus i get 4c off a litre at shell also...
So thats a saving of about 3 bucks a tank... I also get a 600ml coke when i fill so thats a free coke in my books....
50-60 litres of fuel for the car and 600ml of coke for me....
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1796224
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
