I had the fc tuned on optimax and found extreme to knock a bit more but the extra 50km;s per tank has not rally made me a fan... ill stick to 98 plus i get 4c off a litre at shell also...
Are you saying you got the car tuned for 98 ron then ran 100 and it knocked if so i am surprised i would have though the higher ron less chance of knock though if its burning hotter i guess that can happen... also you should really tune it with the petrol you will use all the time.
It arrived in vic on the 16th. I so happened to be the first person at this particular station to fill up with ultimate.
As I went to fill up the clerk started yelling at me from his booth saying its empty but I didn’t really hear what he was saying so I started to pump away.
As I went to pay they clerk was so shocked that he got ultimate back.
Everyone I know says mobile is better. So should I switch over?
damn didnt even know this shortage was happening....must have just ben a thing that happened down south cause we had no problems up here in Bundaberg Queensland. wierd :(
am thinking about swapping over to something else soon though becaue i get pretty bad mileage out of Ultimate. what would people recommend??
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
