hey guys
checked all the piping and made sure it was all tight...
how ever my problems persistists...
After mucking aroudn my with my car... i looked at the ecu and noticed that the stock ecu had been changed. i tried my car with the stock ecu but the problems were stilll happening.
i think its time to see the pro's
cheers guys
  • 3 years later...
Hey guys,had this happen to me last night,the car boosts, but runs crap, I took the controller off, so its running about 9 psi. I'll check all the piping and stuff tomorro. stock ecu, i reset it today to see if it wud make a different.
Any suggestions on what I should check? apart from the IC piping and the wastegate
wow its been a while since i've driven a skyline!
moved on to a 07' gsxr 750, much more reliable machine!
not sure what the forum rules are these days, but usually to get help you gotta be more descriptive!
whats your idle like? any black smoke poring out the back? you running stock gear?
check your pipes, usually thats the case,stock rubber bends do crack, maybe invest in some pretty silicon ones.
cheers, David
  • 3 years later...
hi guys got a c34 stagea got no boost wat so ever got no smoke coming out triple checked every hose ??????????HELP
Lost its turbine wheel. Won't smoke that way if turbine wheel is snapped after the seal grove. (normally are as the grove bit is in steel)
Also u can rey dropping the exhaust from the cat back and then see if u still have issues... Blocked or collapsed. At will cause a car to rev and run like a na car. If u have checked lines actuator and boost then it's another one to check off the list
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
