After waiting for a potential buyer, its time for it to go to someone who has some $$$
Item:Black R33,auto 94 model 97,xxxkms write off
Item Condition:damaged front and rear, no engine damage, interior still very, very neat. car is stock except for the 17s, with near new tyres.
Reason for Selling:dont have time/money to fix
Price and Payment Conditions:$1800ono
Extra Info:vin/chassis - 6T91MPRO6R1JPL021
engine - RB25110668A
Contact Details:Tommy-0402712813
Edited by dOOb
https://www.sau.com.au/forums/topic/98479-damaged-skyline-r33-non-turbo/
is there any damage to any part of the driveline. ie is the damage only to the body (outer shell). if i replaced all the panels will it drive.
please let me know - as i am after a rb25 motor and a shell as well
shaun
ps. i am in melbourne, it does not drive at the moment does it? i would havce to organise freight?
shaunr32
i can be driven, but only if u have to, there is nothing wrong with the driveline , most of the major damages is to the body, front and rear, and its not as easy as just replacing the damaged panels, its a lil bit more work then that.
and yes, interstate buyers would have to organise freight
sorry, i meant when i replace panels and off we go - i am not going to register it. i dont give a sh1t about the dangly bits, all i want to know is that if it is still straight.
if i were to clear all the damage, and give it a wheel alignment , would it drive straight and slide sideways
if not please tell me what else has to be done..
shaun
suspensions, control arms, steering rack/arms, driveshafts looks fine, but i cant promise it will drive straight but i pretty sure it will drive. The problem is the left guard is rubbing against the wheel, worst if ur trying to make a turn. That why its properly better not to drive unless ur really have to.
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
