just based on the number i'd say it's a octboer, november or december 89 model. :) someone with fast can tell you for sure though, but it's definately earlier than 1990 so not a 1992.
https://www.sau.com.au/forums/topic/98480-89-or-92model/#findComment-1790429
bnr32004240
Most likely not a 1992 going on the 4240 number. Probably late 1989 or early 1990. My GTR is 001650 and was manufactured Sept 1989 so that gives you an idea. I'll check in FAST tomorrow, or someone else might beforehand. It's not a website, but a program....do a search and you'll find lot's of discussion.
Edited by SteveL
https://www.sau.com.au/forums/topic/98480-89-or-92model/#findComment-1790437
how can u tell by the numbers and what is fast
https://www.sau.com.au/forums/topic/98480-89-or-92model/#findComment-1790445
sorry stevel the number was wrong its bnr32003239 sorry my mistake
https://www.sau.com.au/forums/topic/98480-89-or-92model/#findComment-1790454
you are not the baron, i am the baron. :)
I am sure there are plenty of Baronies out there that require Barons :)
BTW The is also a user called 'Red Baron' fairly sure he is not Manfred von Richthofen though :)
https://www.sau.com.au/forums/topic/98480-89-or-92model/#findComment-1792304
bah! it seems everyone is the baron of something these days. you may be 'a' baron, but never the baron... hehe :(
That's it. I'm off to request a name change to Rex Banner and I'll get all you Barons, Beer or otherwise.
https://www.sau.com.au/forums/topic/98480-89-or-92model/#findComment-1793929
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
