Guest Vspecman
I know there are some experts out there.
So who can help with this-
My V spec Gtr is one of the last 33's built. It has the vin number as BCNR33 then 43389.
Various engine hoses and the spare tyre have the date of manufacture at 3.98.
Does anyone have info from Nissan or another source to determine when it was made?
https://www.sau.com.au/forums/topic/985-how-old-is-my-gtr/
The series 3 continued to be built into the early months of 98 so it could still be built in 98. I'm not sure why you are checking up on it but if its because you think its not a genuine late model one then you can also check for all the other things that are on the series 3 such as HID's front lip, red stitching on the seats etc etc
https://www.sau.com.au/forums/topic/985-how-old-is-my-gtr/#findComment-21137
Guest Vspecman
thanks tonyxc and 400hp.
I am hoping there would be some Nissan production information showing when certain vehicles were produced. I am amazed that Nissan does not readily provide such information.
Cars like Mercedes Benz and Porsche have a long Vin number which is easily decoded to tell you production date, which part of the world the car was built for, LH or RH drive etc which is essential info when buying an import.
The last of the 33 V spec cars were produced after production of the 34 GTR cars had commenced.
Tomorrow I am picking up a R34 V spec from a workshop where it has just had N1 turbos, power FC etc installed and taking it for run on a 4wd dyno.
Any specific info on the production dates would be appreciated.
https://www.sau.com.au/forums/topic/985-how-old-is-my-gtr/#findComment-21170
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
