Hi All,
was informed last night at willowbank test n tune (same as a street meet in sydney) that as the andra rule book currently states if you run 11.99 or faster you now require a 4 point saftey harness!
Apparantly a rule thats been in there for a little while and hasnt been enforced.
They was also on top of alot of the saftey stuff last night, pretty much actually checking every helmet had the sticker to show it met aussie standards etc.
Ah well just a shout out so everyone knows. Get yourself a harness.
btw i ran 11.41 @ 124mph gotta get tires its all over for me. lol
mick
https://www.sau.com.au/forums/topic/98505-new-rules-for-1199-and-under/
Hi All,
mick
Yeah Mick...its an old rule, and i think someone from up that way stirred it up. Will be enforeced from now on.
Congrats on your 11.4...well done
yeh thats what it seemes like.
looks as if they was on a saftey rampage. lol
which if you ask me is fair enough.
re my time, yeh im really struggling getting off the line need to ditch my street tires and get some semis.
http://www.gunnamotorsport.com/vids/wrxkilla32gtr20.WMV
this is marc jacobson i missed 3rd and went 11.7
http://www.gunnamotorsport.com/vids/wrxkilla32gtr22.WMV
solo run i another 11.4
hey morgs yeh
but as demonstrated in that thread i had back then, you have to look at my dyno graph.
With an old school to4r (mine has 0.96too)its very laggy and doesnt make great accross the range power like the t04z say.
so peak power accross the gears is low. it only makes the peak power for a small amount of time in high rpm. so its not ideal.
it was tuned yesterday before the track with 398kw at 4 on 18psi wastegate pressure.
Hopefully with some practise, tires, i can get some higher 12xs mph
its a step by step
getting there
mick
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
