the story goes like this:
My car - r32gtst came over without a belt thrown over the AC compressor, and a lot of cooked rubber stuck to that particular corresponding section on the crank pulley. So I bought a new belt dayco belt for the AC Compressor..
So I took the PS belt off, no problems there.. then the alternator belt/water pump belt, still no problems. And I began working away at all the cooked rubber on the crank pulley.
Because I was working away at the crank pulley, I was working at it from underneath the car, with a knife and a wire brush, picking/scratching all the little bits of rubber from the crank pulley.. because I was working underneath the car, I only have access to a certain section of the crank... So I would clean a section of the pulley, crank the starter motor quickly without starting the engine, and hopefully expose an uncleaned part of the crank for me to clean..
So I cranked it once, cleaned it, all good.. Second time I hear a pop, and looking throught the gap in the bonnet (from inside the drivers seat, I see smoke shoot out from somewhere within the engine.. I was like f**k.. then I got around to the engine and tried to work out where the smoke was coming from.
At the time, I had the second pipe that connects to the plenum off (RB20DET, the one that runs from lower right corner of the engine bay, to the curvey elbow pipe before the plenum) - because I had to get the powersteering, as well as the vaccum hoses from the emissions box and, as well as the power steering and alternator/water pump belts.
The smoke seemed to be coming from the intake pipe that was still connected to the engine, and it smelt like a burning smell (rubber or plastic burning)...
Now the only thing that I can think of, is that maybe a little piece of rubber SOMEHOW got into the intake while the pipe was off, and became part of the combustion process, what I don't understand, is that if this was the case why would all the smoke be backfireing out through the intake, as oppposed to the exhaust.. So I really have no idea what the f**k it was.
I put the pipe and vaccum hoses back on for the remainder of the time when I was cleaning the pulley and cranking the engine, just incase something managed to get into the engine..
Upon reconnection the altternater/water pump belt, I started the engine and let it idle to see if everything was cool, It idled at 1,500RPM..
I then went to put the AC belt on and realized that it would NOT fit... So all this crap was completely for NOTHING!!!!!
then I put the powersteering back on with no problems.. So now, everything is back together, and the car idles at 1,100RPM, however I didn't give it much time to see if it would drop down to or so, and I haven't run it around the block yet (but I will).
Things seem to be OK at the moment, I was just wondering if maybe what happened with the smoke - if that was something really obvious to people, is there anything that I might have missed, should be doing should be checking... It may seem ok now, but what if it's something waiting to explode/breakdown/whatever when I'm sitting at the bottom of a hill?
https://www.sau.com.au/forums/topic/98539-pop-smoke-funny-burning-smell/
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
