After I replaced my rocker cover gaskets I started the car and it was on 5 cylinders so I thought I might have accidently knocked off one of the coilpack cables loose. But to my suprise all were on properly but I reseated them anyway but still no luck.
Today I decided to check the coilpacks and it seems the 3rd cylinder doesn't do anything but the actual coilpack sparks when off. So I tried to swap coilpack #3 with #1 (knew was working) and to my suprise the same thing happened. Therefore ALL my coilpacks are WORKING!
The question is if all my coilpacks are working why is it that the 3rd cylinder won't fire? :)
I took out the spark plug in the 3rd cylinder to check and that was fine. So that leaves the ignitor pack which i just noticed has a crack on the top. Would that crack be affecting it at all??
https://www.sau.com.au/forums/topic/98541-running-on-5-cylinders/
Update: OK I tried to have a look again by pulling out the coilpack, I only had to pull it off a couple off centimetres and the sparks were already flying to the side (very high) :S
So I'm assuming this means the spark was going away from the spark plug. So I tried to put electrical tape around some areas... didn't work. Then I gave up and decided to try WD40 into the coilpack. And now for some reason it works!
Happy, but still angry because I need a permanent fix before I put it all back together and I have no idea where to begin :)
Would really appreciate it if someone could let me know the exact problem so I can fix it properly. Thanks guys.
There is an article in the latest Zoom (or maybe it's HPI) about the tendency of these coil packs to arc to earth when the rubber boots get a bit dirty. Spraying with WD40 maybe increases resistance to the path to earth.
Try giving the boots a good cleanup.
Thanks blind_elk. I guess I'll just clean them all out and spray good'ol WD40 in and see how long it lasts. Don't have money for splitfires at the moment.
I also broke one of the coilpack wire connections because it was so brittle but it seems it is still working even with less plastic insulating inside the plug between the 3 pins.... Oh well.
the problem is uve got a build up of gunk on the inside of your coil packs. take them all out and either get a dremil drill and sand the inside of the coils lightly, or get some steel wool with some WD40 and clean the inside of them.
as electricity takes the quickest ("easiest") possible route to earth, because of the build-up inside the coil pack, the route to the spark plug is no longer the "easiest" route.. i used a dremil on mine and this is what they looked like after:
there was a big difference with before and after, now i get a damn good spark with no misfire.
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
