hmmm.
well i just had my emanage fitted. and the tuner said that the airflow meter is maxed out at 180rwkw at 12psi??
i know my brother using the exactly the same afm on his r33 was pulling around that 200-220rwkw mark with pfc.
the tuner said that i will need z32 afm as mine is maxing out at the moment at 5volts?? he is saying that the ecu is not liking any more than that?
its got me F**ked i wonder why. I need some expert answers ;P??????????????????????????????????
could the greddy emanage be running a different current to the afm than the pfc?
Why not consider the extra map sensor plugin harness for the emanage.
It will read boost pressure off the map sensor once the afm maxes out.
Just a thought.
yeah i was looking at that on mohd parts. thankyou most helpful. i wasnt 100% sure what it did.
Just a thought.
How does that help?
The boost controller should be ensuring that the boost stays constant, especially at the sort of rpm the AFM is going to be maxing out at. So the MAP sensor shouldn't see any differences in the pressure. That means there is no variation in the load signal to cause the load mapping reference to move. So all you get is RPM mapping reference changes, which is what you would get with a maxed out AFM anyway.
The only time you really need an AFM upgrade is when unanticipateable changes in airflow occur, ie; not linear with rpm changes. At high rpm (ie; past boost build and camshaft timing effects) this shouldn't be an issue. The fuel and ignition requirements are satisfactorily driven off the rpm change.
That's why I don't change the AFM's until it is necessary because of tuning requirements, and reaching 5.1 volts at 6,000 rpm in an RB25DET is not one of those. It would seem that RacePace have a similar philosophy.
:D cheers :(
How does that help?
:huh: cheers :)
Yeah your right.
But with regards to the original question, i was under the impression he wanted to run more boost then what he had, which would require someway of the ecu knowing that the extra boost is being run.
Yeah your right.
It's not the amount of boost, but the change in boost that the ECU would need to make use of for mapping purposes. MAP sensors are usefull when boost is building or decaying. But when the pressure stays the same for periods of RPM change they are not much use at all. You still have to use the RPM axis to determin the fuel mapping.
:huh: cheers :)
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
