  • Replies 190
Posted Images
Stolen! It has never been registered!! It just got off a boat from Japan and it couldn't get on that boat if it was stolen (de-registration papers) so yes, waste of time!
Nice work RTA!
Agreed!
all did not go well on tuesday...however, i put in the 500HP fuel pump, and am putting the new platinum spark plugs in tomorrow morning. if all goes well, it will be rego'd on monday
CAR IS RUNNING!!!
fuel pump was almost dead ie not flowing enough,
and the major problem was a relay on the ignition coil circuit decided to croak it.
...makes it hard to diagnose the problem without a wiring diagram.
but the most important part of all is... its all systems go for rego on monday!
i put the walbro 255L/hr pump in, it was similar to the factory pump other than the one end which had the hose and the plug positions swapped around.
still managed to secure all of the clips in the cradle it sits in, other than one of them.
yeah car is registered, and constantly being driven :D
i sure am going through a lot of fuel... ill let everyone know how many k's i get out of the first tank in the petrol thread.
my stagea no longer has a camo front bar :):):)
ill change the pic in my signature whenever i get around to it :P
i picked it up yesterday from the smash repairers.
i also forwarded both of the invoices for repair/painting of my front bar to KIPS and i got an email back saying that they will pay me next week WOOHOO!!!!
  • 1 month later...
well its taken ages but i finally got the money from the insurance claim through KIPS today, i was beginning to get a bit worried for a while there, i didnt want to have to cop the $900 repair bill.
God Damn - Im so stoked that I havent had ANY troubles whatsoever with my Stagea (well, besides dills drilling into my wiring loom when the cdstacker was installed under the passeneger front seat).
touch wood hey! :P
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
