Ice Performance just finished dyno tuning my GTR tonight and I am very happy with the result.They actually hit a peak of 365rwkw,but toned it down to a safer 351.9 rwkw.
The car has
HKS 2530's
HKS dumps
HKS 264/264 cams
Z32 afm
Tomei pump
Nismo 600cc inj
Power FC
HKS ebc
HKS super dragger exhaust
Trust cooler
Arias forged pistons
This was done using Boost98 E10 fuel,if Extreme100 was available in more servos I would have used that.
https://www.sau.com.au/forums/topic/98582-r33-gtr-dyno-resultcamsafmpump/
Nice result. Was talking to G about it before.
Love the rocker cover pics... G has been raving about the colour that Nick did em... it sure does look farking brilliant!
[/quote
Gerald has claimed the color,its called "ICE G GREY" :lol:
In 4th gear its making
5 psi @ 3000rpm
10 psi @ 3800rpm
15 psi @ 4100rpm
20 psi @ 4500rpm
22 psi @ 4700rpm
It makes over 300rwkw from 4800rpm,still making 350rwkw + at 7500rpm,extremely flexible on the steet.
The only other mod I want to make is to fit HKS exhaust manifolds,expensive labour wise for a small overall gain,but response should be even better.
M&M nice work and nice result for such low lift cams. I can personally say the HKS manifolds are the shit (awesome construction quality) and can i ask did you play with cam timing and if so what did you find to work the best.
pete
ps nice engine bay
I dont have an adjustable cam gear on the inlet side,only the exhaust.I was going to ask on here what sort of results people have got with this setup, which should be fairly common,with cam timing adjustments.We have left it alone at the moment,maybe in the future.
well i would most definitely put an adjustable cam gear for the inlet on the wish list and you can really adjust the sort of power you get and quiet offen (most chaces increase out right hp) with adjustment of the cam gears. the inlet tends to adjust how early the power will be made ie a little advance can quiet offen bring the whole power curve on earlier and the exhaust advance can offen give a bit better top end hp. I stress every motor is different but i have not seen a setup (rb26) not responce to cam timing in some fashion its offen only other factures that limit the gains that can be had for cam timing ie the turbos reached peak efficience etc
pete
I really thought most of the benefits with adj cam gears was with stock cams.I would have guessed that HKS cams would work best straight up,or that gains would be minimal.Anyone have dyno figures of gains or do I have to be the guinea pig?
dude your no guinea pig i have worked the cams on like 6 different rb26 all have responded to timing some a little some a lot. The first of which was my own awhile back
http://www.skylinesaustralia.com/forums/in...=ST&f=8&t=48595
the least gained was still around 30rwhp with less than half the timing i had to put in mine. Each motor is different and dont always think that a little cam timing is different you may just be adjusting the cams to the correct relationship to crank as manufacturing tolerances can cause differences in this (we are talking small) but considering that 2 deg of crank timing (=1 deg of cam timing) gave me 30rwhp a small difference can be of great benefit Yes?
pete
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
