Ice Performance just finished dyno tuning my GTR tonight and I am very happy with the result.They actually hit a peak of 365rwkw,but toned it down to a safer 351.9 rwkw.
The car has
HKS 2530's
HKS dumps
HKS 264/264 cams
Z32 afm
Tomei pump
Nismo 600cc inj
Power FC
HKS ebc
HKS super dragger exhaust
Trust cooler
Arias forged pistons
This was done using Boost98 E10 fuel,if Extreme100 was available in more servos I would have used that.
https://www.sau.com.au/forums/topic/98582-r33-gtr-dyno-resultcamsafmpump/
Nice result. Was talking to G about it before.
Love the rocker cover pics... G has been raving about the colour that Nick did em... it sure does look farking brilliant!
[/quote
Gerald has claimed the color,its called "ICE G GREY" :lol:
In 4th gear its making
5 psi @ 3000rpm
10 psi @ 3800rpm
15 psi @ 4100rpm
20 psi @ 4500rpm
22 psi @ 4700rpm
It makes over 300rwkw from 4800rpm,still making 350rwkw + at 7500rpm,extremely flexible on the steet.
The only other mod I want to make is to fit HKS exhaust manifolds,expensive labour wise for a small overall gain,but response should be even better.
M&M nice work and nice result for such low lift cams. I can personally say the HKS manifolds are the shit (awesome construction quality) and can i ask did you play with cam timing and if so what did you find to work the best.
pete
ps nice engine bay
I dont have an adjustable cam gear on the inlet side,only the exhaust.I was going to ask on here what sort of results people have got with this setup, which should be fairly common,with cam timing adjustments.We have left it alone at the moment,maybe in the future.
well i would most definitely put an adjustable cam gear for the inlet on the wish list and you can really adjust the sort of power you get and quiet offen (most chaces increase out right hp) with adjustment of the cam gears. the inlet tends to adjust how early the power will be made ie a little advance can quiet offen bring the whole power curve on earlier and the exhaust advance can offen give a bit better top end hp. I stress every motor is different but i have not seen a setup (rb26) not responce to cam timing in some fashion its offen only other factures that limit the gains that can be had for cam timing ie the turbos reached peak efficience etc
pete
I really thought most of the benefits with adj cam gears was with stock cams.I would have guessed that HKS cams would work best straight up,or that gains would be minimal.Anyone have dyno figures of gains or do I have to be the guinea pig?
dude your no guinea pig i have worked the cams on like 6 different rb26 all have responded to timing some a little some a lot. The first of which was my own awhile back
http://www.skylinesaustralia.com/forums/in...=ST&f=8&t=48595
the least gained was still around 30rwhp with less than half the timing i had to put in mine. Each motor is different and dont always think that a little cam timing is different you may just be adjusting the cams to the correct relationship to crank as manufacturing tolerances can cause differences in this (we are talking small) but considering that 2 deg of crank timing (=1 deg of cam timing) gave me 30rwhp a small difference can be of great benefit Yes?
pete
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
