hi, i need to have a new key cut for a r32, i was just wondering if any1 knows if i can get this done through nissan, as i have the original key for my car and it was fairly worn and mildly cracked. i could get it done through a key cutter but it wont last too long i wouldnt think. cheers guys
Edited by Turbz_13
https://www.sau.com.au/forums/topic/98594-key-cutting/
I got the key for my R32 GTR cut by these guys:
ADELAIDE LOCKSMITHS
Adelaide 150 Hutt St 5000 (08) 8223 5433
Po Box 7005 Hutt St Adelaide 5000
After Hours Emergency Service (08) 8223 5433
Fax (08) 8232 1768
Mobile Service 0408 832 951
Did the cut off the computer code, not off the old key so it's as good as a new one that came from the factory.
I didn't want to waste my $60 genuine GTR key :D
Edited by chalon
https://www.sau.com.au/forums/topic/98594-key-cutting/#findComment-1795517
wat about r33 keys dat comes with the central lockin on the key?
key cutters say it cant be cut?
dont quote me but i would say its more ethics as to why they dont do it rather than it CANT ...
ie ur drunk @ a party thats gone into the next day and ur mate steals ur keys and goes to try get them cut...
or uve had them stolen @ the local swimming center
or they fell out ur pocket and sum1 found them
well i think u get the picture
https://www.sau.com.au/forums/topic/98594-key-cutting/#findComment-1798003
werd
https://www.sau.com.au/forums/topic/98594-key-cutting/#findComment-1798082
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
