Allright i know that the cancellation of this cruise was a big dissapointment for every1 to say the least.
Is there any1 out there who wants to go for a cruise and meet @ 10am this sunday.
Post up your interest and destination.
I guess if we did still hold one it would be a meet in the same place just cruise somewhere different.
Hell i dont really care if we cruised to newy like origionally planned.just that theere is a cause for concern.Hence the asking for input.
We could allways give our input on the day.And the destination doesnt have to be any further than the distance to newy.
#WHATEM SAY#
Edited please read.
Boys.And girls.ill say this.
I cant come on sunday due to underlying cicumstances beyond my controll.
I am shitted to say the least but there was nothing i could do about it.
I am all for helping you guys out forum wise with the organisation of it all.But thats as far as i can go for this cruise.
I will have to wait for the next cruise now.
You should all still go ahead with it.And yeah post up the pics of it.:D
Craig.
https://www.sau.com.au/forums/topic/98606-who-still-wants-a-cruise-this-sunday/
#WHATEM SAY#
I still want to cruise on sunday for sure.. but yeah not to Newcastle.. I still wanna meet same time and place, sounds good to me!!!
I will be marshalling and driving at the Kids Race Day this Sunday.
Its a charity event for handicapped kids, to give them a taste of the track. If you've got nothing else on, you can always cruise on down to Oran Park and have a look.
There won't be an entry fee as such, but donations would be nice.
Yeah we could make ''oran park'' part of the cruise.If thats what every1 wants.Then bounce somewhere else.Or end up there at the end or whatever.
I will have to get your details so i would know more about the event.
Craig.
You should all still go ahead with it.And yeah post up the pics of it.:huh:
Craig.
cruse is still on inewy but we wont be going anywhere near noby's unless hav ok of someone in there.Look all sydney people still should come up the cops are very good up here as long as u dont have bald tyres your right.I ve never been pulled over and checked for defects yet there after lowered vans air bags that are not safe.I havnt seen them defect a person in newcastle for 6 months.
As for riots i think its going to be fine just young kids sending chain texts like emails.
Dont call it off, we want to meet u all we can go to redhead beach which is 20 mins from newcastle or somewhere else.
cant wiat till tomoz its cleared up now, so time to clean car now.
NO ULTIMATE STILL IT SUX
heres my mob number (0412573011)- u can ring me if u want to find out where newie crew is tomorrow
looks like its going to be a great day , hope to meet up tomorrow
Edited by bake
i'm in for SURE !! :) .. Just got my car yesterday and would love a cruise even though i did show it off abit last night :)
Jeez the thing loves petrol though :P , i filled up 2 3/4 tanks within 5 hours
first tank was 95 octane because 98 was out :D
P.S. Im coming cruise :) :)
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
