Prob sounds a little funny, but unsure of what power its making at the moment as when i picked it up, the workshop had forgot to print out the graph for me. Have to go back once they open again....also, there's still a few little issues i have with the tuning that they have done (runs a little rough, couple of flat spots, etc).
Its already got a Bosch 040 pump in it, and have Sard 700cc injectors, Tomei 260 poncams and an adjustable fuel reg to go in next.
Im looking at getting the bottom end rebuilt also, I know that forged rods and pistons are a must...what other areas should i look at while rebuilding??
My R32 GTR (i just sold it last week) :D
was revving to 8500rpm. Tomei rods, pistons, cams. stock crank. was fine when i had it.
but with anything.
Big Revs & Big Boost = Big Bangs
hahaha
nah seriously, sustained thrashing, repeated high revs with high boost is bound to cause more wear and tear on a motor and shorten its life.
theres prople running 9000, 10000, 11000 rpms on RB26s...
depends on the exact hardware....
just how often to you want to rebuild it
Revs dont always = more power.A person of moderate intelligence would do a power run on a dyno,see where max.power is made and where it starts to fall away.Then purchase a shift light and then set it to trigger 3-400 rpm below peak power.Generally the majority are suprised to see where peak power is made.Usually well before this 8500 crap.
lol
what you are describing is not always the case either...
i might not be making more power at 8500 than 7500, the more average revs you have your car in the max powerband the faster it would be.
so for example.
4500rpm - 200kw
5500rpm - 250kw
6500rpm - 275kw
7500rpm - 310kw
8500rpm - 295kw
So in this case my average power accross this range is: 266kw
If i change my limiter to 7500rpm it is 258kw
Thats a lame example but proves the point. In my Case it was more extreme and was very helpful to have a higher average power output.
thanks
Michael
Wouldnt you want to set it 400-500rpm above max power so that when you shift it doesnt dip much below max power?
lol
so for example.
4500rpm - 200kw
5500rpm - 250kw
6500rpm - 275kw
7500rpm - 310kw
8500rpm - 295kw
thanks
Michael
Average power?? thats for dyno comps.In real world,once u pass max power mark,you are going slower.Revving uselessly for no gain
no because reaction time.light triggers so by the time you shift,you are at about max Power.
Im talking about on a track, surely you would want to shift slightly above max power, it makes more sense and everyone has always told me to do it as this way you will have more power in the next gear.
eg.
let use the above dyno results and assume a 2k drop in revs.
Shift at 7500rpm 310kw and it drops to 5500rpm at 250kw average power = 278kw
or shift at 8500rpm at 295kw and it drops to 6500rpm at 275kw average power = 293kw
Shifting higher = more power available across the spread.
Yes you are correct you wont be making as much power at the top of the gear but once you change gear you will be making more then if you shift lower and hence your overall average power will be higher. Say once your in a high gear like 4-5th and the revs dont drop as much you could work it out and probably shift much lower then in early gears like 1-3rd
Not sure of what exactly needs done to rev high, but probably stronger crank bearings for a start...
As for the change point, you are always going to accelerate faster by revving an engine out, due to the increase in tractive effort (torque applied to the road) in a lower gear - gears are just torque multipliers...
Revs are a very good way to more power - which is just a factor of torque x revs - my T78 spools after 5k (maybe 4.5k in higher gears) and would be a pain to drive if the engine wasn't built for 8500rpm...
Cheers :blink:
Rog
BZZZZZZ. WRONG.
have a think about it...
heres one of my first dyno sheets. this wasnt how it currently is but its a great example...
all kw at 4 wheels
http://www.gunnamotorsport.com/wrxkilla/415.GIF
So with a 7500 limiter i change gear and it goes back to 4500rpm and accelerated again..
4500rpm -100kw
5000rpm -140kw
5500rpm - 190kw
6000rpm - 280kw
6500rpm - 330kw
7000rpm - 380kw
7500rpm - 415kw
Average 262kw
With an 8500 limiter i change gear it goes back to 5500rpm (note last 2 are guess as its not plotted obviously)
5500rpm - 190kw
6000rpm - 280kw
6500rpm - 330kw
7000rpm - 380kw
7500rpm - 415kw
8000rpm - 410kw
8500rpm - 400kw
Average 343kw
Now Peak power means nothing. Your telling me that if i have an average of 80kw more accross my rev range (thats used through the gears) it not going to be faster?
your argument makes no sense...
lol
Sure helped me at the track...
michael
shouldn't you look at torque moreso?
you want a huge torque curve from idle to redline, big and flat!
(haha well your not gunna get torque from idle on a small capacity RB) but the idea remains, huge wide torque band/curve for quick times.
Tractive effort curves are the best - i.e. torque at the road.
e.g.:
You see how tractive effort decreases in each gear, and you should change up when the lower gear curve drops as low as the next gear's tractive effort...
Cheers :)
Rog
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
