Have you found why it keeps blowing fuses?
Search for the Nissan FAST thread, post in there they will help you out with part numbers and stuff like that
  • Replies 49
Posted Images
I think it's because of compressor but not so sure yet. and taking it to work shop this wed to find out.
where do I look for FAST thread??
I've been searching for part numbers and model but no luck so far!
hey got my a/c done today phil is a top bloke he knows his stuff..benm have u got power fc??? Think it was u at the Cruise to coalcliff beach with bonnet up etc? well if you do i have power fc the thermo fan for the condensor doesnt kick in...so he used a wire to link the relays in engine bay for a/c and thermo fan , you mite find thats what he might do to urs aswell. the thermo fan will kick in when you turn a/c on, sumthing to do with the amount of pressure build up and the thermo fan when kicks in will reduce that pressure build up etc Happy with the job done by phil, got sum cold air now :P
Thanks N1 2 for organising.
  • 9 months later...
hey champ wanna get my ac checked out, could you post up his workshop addy or pm me
cheers
hey mate.
He works by appointment only as he is a mobile technician.
He's got the whole setup at his home, and runs around syd.
If you're keen, give him a call on 0418 608 680 to book a time.
I don't think he'd be too keen on me giving out his home address, so give him a call and he'll give you a time and where to go.
it'll be a good decision if you do, as he knows his shiz.
cheers, Sasha
  • 1 year later...
i dont suppose there is any Victorian equivelant to this air con guru in melbourne? hehe i could really use his expertise right now. Anyone know of any air con specialists in melb?
Yeah its an old thread but the bloke will still take care of sydney people. He's going to be doing my gtr again in the next few weeks (ac came out for the rebuild)
Best bet for victoria would be to call some local people and ask if they would like the opportunity to make some money from a group of people that will be all aking for the same thing :D
Guest
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
