My Ride Thread :) Artistic Or Not; Put Them On
  • Replies 262
The stagea, before it goes off to the painters.
Add R34 N1 air vents to the front bar, nismo eyelids.
Metallic blue 20mm pin-strip on the bodyline, above the door handles. White with VERY subtle silver/gold pearl from the stripe down.
And my 最高ガレージ (www.saikoogarage.com) logo, in massive D1 style, plastered up the side.
Hopefully slidewize will get me teh new front grille...
Paint scheme isnt set in stone... anyone got other ideas......????
umm... looks like the ghost of the previous owner is in the drivers seat in taht first pic. creepy. Nice car - LOVE the S2s. Never seen one with 350Z wheels.
Good locations - reminds me of zoolander, showing off his versatility lol
yeah I saw that too. and this is no photoshop edit just the original size pic. way creepy
maybe aboriginals are right, cameras do capture peoples souls.
But let me ask you this, how many abodiginals do YOU see male modelling? Lols love that movie. :D
I have some slightly more 'versatile' shots. :D
qikstagea your stagea look tough from the front, me likey! Hanging out for your pics after the makeover.
If you ever do decide to go this way let me know, my car can be the first customer for ur bustin
Thanks for the comments guys!
Edited by The Milf Guy
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
